60 Hz Hum
60 Hz Hum
Old 25th October 2001, 03:47 AM   #1
Chad is offline Chad  United States
I just finished the http://www.aussieamplifiers.com N-channel, and it has a hum. I measured it with a hz meter and it is 60hz.
When I short the input it stops humming. Not sure if that means anything but that is how we tracked down ground loops in car audio. The pre amp is a Adcom GTP-600. It does not hum when connected to the GFA-5500. I tried unhooking the chassis ground but that didn't stop it. Any ideas on how to stop it?
Thanks in advance,
Chad
Old 25th October 2001, 03:51 AM   #2
GRollins is offline GRollins  United States
Chad,
Any chance of a bad connection for the ground of the input jack? Cold solder joint? Loose mechanical connection?
Grey
Old 25th October 2001, 04:03 AM   #3
Grollins,
Everything seems alright, solder looks good, connections are tight. When I shorted the input it was at the end of a 6ft RCA cable that was plugged in to the input jack. So I think the input is alright, but I will double check everything. Thanks for the reply.
Old 25th October 2001, 05:03 AM   #4
fcel is offline fcel  United States
May be one of the ground trace on the circuit board is open due to the "accident" as reported on your other thread?
Old 25th October 2001, 06:07 AM   #5
Dave is offline Dave  New Zealand
60 Hz Hum
The hum could be due to your power supply layout. I found that using separate rectifiers for the positive and negative supply rails helps to minimize the chances of a loop. Each secondary winding should feed a bridge rectifier, which are then connected to the power supply capacitors. The ground point should be made at the capacitors and all ground leads connected at this point. +/- Connections should also be made at the capacitor terminals not at the rectifiers.
Hope this helps.
Old 26th October 2001, 03:16 AM   #6
Thank you all for your help. I found the cause of the hum. Believe it or not it wasn't the amp. It was my X-10 signal bridge in my main breaker panel. It was on the same circiut that the amp was plugged into. When I changed plugs the hum stopped. So I plugged the amp back in and moved the X-10 to another ciruit. Now my amp works fine and so does my home automation system.
Chad
60 Hz HumHide this!Advertise here!
Resources saved on this page: MySQL 17.65%
