I have a Dynaco 400 with a missing diod block. Thus resulting in a
dynaco. I was wondering if anyone knew of a replacement part and what the spec of the original were? I think it is the same block as the hafler dh 200 but I don't have any specs on that one either.Help is much appreciated, thanks, Bill |
#2 |
I'm sorry I don't have the specs. for the bridge of the Dynaco ST400 for you. I do however own both of those amps. The bridge in the Dynaco should be rated fo 200 volts and 25 amps. I'd go for a 35.amp bridge myself. The Hafler operates at lower voltage and current that the big Dynaco so I don't think they use the same bridge but it could look similar.
Later Bruce
What ever makes the tunes flow |
#3 |
I have worked on lots and lots of dyna400's over the years
and have never ever had a diode bridge failure. After putting in the new bridge, before you turn it on, pop the 4 fuses and turn it on. One of the main electrolytics might be shorted in which case something is going to pop, so stand back when you turn it on. |
#4 |
thanks Bruce ,
that's what I needed to know, I ordered a new 200 volt 35a form digi for a whopping $2 and some change and thanks Kevin, I will do that. My cousin's went out about four years ago and he had a tech replace it but it was the only thing wrong in his. I hope i am that lucky. |
| preamp suitable for Dynaco st-70- OTHER than dynaco | namatjira | Tubes / Valves | 3 | 22nd December 2011 01:21 AM |
| Need help finding a diod. | CJ900RR | Parts | 2 | 16th January 2008 04:18 PM |
| Diod bap811 | bengt | Solid State | 12 | 11th May 2004 04:26 PM |
| AA118 does anybody know what diod type that is? | hifi | Solid State | 4 | 20th February 2002 01:51 AM |
| Éxtremly slow diod to "muffle" toroid | hifi | Solid State | 1 | 31st January 2002 07:44 AM |
| Page generated in 0.07156 seconds (76.22% PHP - 23.78% MySQL) with 10 queries |
