Hi, a bit of a newb here (build speakers though, new to amps), I am looking for a kit recomendation for using 4 bookshelves and a powered sub, looking to spend around 200 or cheaper
also a quick question: if I build a sweet amp and send the signal to my sub then route that to my speakers will that nullify the quality of the amp I built because it is being sent to the sub then the speakers? and if so is there an amp I can build that can send the signal to the 4 bookshelves and the sub at once (This would be great), thanks |
#2 |
you need 5 amplifiers to drive 5 speakers. You have to decide if you want 5 monoblocks, or 2 stereo amps and 1 monoblock, or a 3channel plus 1 stereo, or a 5channel amp. The worst performance will probably come from an integrated 5channel commercial offering. Once you have made this decision, you can decide how to split the audio signal. Summed mono, low pass filtered to the bass amp and high pass filtered stereo signal to the 4 bookshelf amplifiers.
regards Andrew T. |
#3 |
dont know if this changes anything but my source is a computer so we are starting from a USB DAC
could someone recommend a kit or an amp that would do what andrew said, I am confused how I would set it all up using 5 amps to drive 5 speakers (and also cost less than 200$) would I be using one central hub that sends a signal to the individual amps and speakers also should I get a powered sub or not? If I build an amp specially for the sub I wouldnt need one correct? If I did this where would the "crossover" occur (filtering of high freq.) |
#4 |
What's the first decision you need to make?
Then decide where to locate the crossovers.
regards Andrew T. |
| Really basic TL question | weinstro | Full Range | 3 | 11th October 2007 05:16 AM |
| Basic RC Value Question | SRMcGee | Tubes / Valves | 6 | 13th August 2006 05:39 PM |
| really basic question | cuallito | Tubes / Valves | 6 | 15th April 2004 08:25 PM |
| Basic question | Tommy | Solid State | 6 | 22nd February 2004 03:08 PM |
| really basic question | MbayAQ | Digital Source | 3 | 7th January 2003 12:57 PM |
| Page generated in 0.07112 seconds (71.21% PHP - 28.79% MySQL) with 10 queries |
