Old 13th March 2007, 11:03 AM   #1
tadiam is offline tadiam  Argentina
Send a message via AIM to tadiam Send a message via MSN to tadiam Send a message via Yahoo to tadiam
Default here links diy schemas
Hi diyers i found this links in the web……
http://www.zero-distortion.com/tests...powertrans.htm
Choosing Your Power Transistors
http://www.zero-distortion.com/downlaod/extra_dl.htm
ampssss schemass
www.fmturnerinfo.com
All about fm turners… schemas too….
http://www.turneraudio.com.au/index.html
Amps schemas….
http://www.sharediy.net/article_list.asp?c_id=7&s_id=32
Surf here…..i found 18 amps schemas
http://www.radiolocman.com/electrica...z=2&wo=1&ord=1
amps….
http://www.audiocostruzioni.com/r_s/ampli/ampli.htm
more amps and photo
audio
Old 13th March 2007, 11:18 AM   #2
Gordy is offline Gordy  United Kingdom
Hi tadiam,
Keep looking around the internet and you will find many, many, many, many more!
Old 13th March 2007, 12:46 PM   #3
Default okkkk
only are an small portion of this........
audio
Old 13th March 2007, 02:07 PM   #4
Send a message via MSN to aguantesoda
thanks tadiam, but some of the links doesn´t work...
*gracias tadiam, pero algunos de los links no funcionan.
Old 13th March 2007, 08:09 PM   #5
Default que tal
aguantesoda esta muy muy cerca merlo de ituzaingo
comunicate al correo mio despues te envio otros liks
gracias.
decime cual no funciona......
audio
good link schemas an audio in general tadiam Solid State 8 12th November 2007 11:18 PM
Marantz CD 40 schemas and DIY suggestions? seppstefano Digital Source 0 10th March 2004 08:00 AM
need for links Guss The Lounge 2 6th September 2003 04:46 PM
I ask for schemas of preamplifiers of class A. Help Ms. Nelson Lukas Pass Labs 9 6th April 2003 11:08 PM
Page generated in 0.07809 seconds (75.66% PHP - 24.34% MySQL) with 10 queries
