Hello everyone I am interested in building my own amplifier. I have only had experience using solid state amps. NAD, ADC, Yamaha primarly. What are the differences between solid state, pass labs, chip amps, and tripath amps (like ones from 41Hz.com)? Which ones are the best to get the most power, cleanest power, and authority in the lowend frequencies? At 41 hz they have one that does 200 watts at 8 ohms for like only 85 bucks? Do these produce true power? Also on whatever amp you guys suggest, what amps (as far as quality goes) in the mainstream field do these DIY amps compare to?
Sorry for all the questions and thanks for the help Dan |
#2 |
Not so long ago someone came by and asked for a list of reference amplifier designs from the diy folks here. THIS thread was generated in response.
I don't know if it helps you but perhaps it is worth a look? The first post on the thread is the result of the entire thread behind it. I think it is a good "snap-shot" of some choice options available. Have a look see. Cheers, Shawn. |
| I want to try and build my own DAC | gareth | Digital Line Level | 3 | 3rd July 2009 03:20 PM |
| ZV9 build | ingi | Pass Labs | 8 | 6th August 2006 02:40 PM |
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 07:54 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 09:52 AM |
| Page generated in 0.05822 seconds (73.70% PHP - 26.30% MySQL) with 10 queries |
