As the AV400 adjusts and where the measures are taken, voltmeter in vdc and bornas where they are put.
thanks |
#2 |
All these values are verified and agree with the table of down.
R3~1.6 volts R5~1.6 volts R15~1.0 volts R12~500mv R13~500mv R8 ~14.6 volts ZD1~15 volts Offset voltage at R11 should be close to 0 volts, but can be as high as 100mv. |
#3 |
But first connect the voltmeter across one of the o/p stage Source resistors using Alligator leads.
Now reapply power to the amplifier and slowly adjust P1 while watching the voltmeter, for a reading of 18mv. This sets the bias current in the output stage to just under 100ma per device. In as resistance checked, in those of 0,22 ohms. or in the 470 ohms. thanks |
| The AV400...... | aleopeldd | Solid State | 11 | 16th September 2008 11:18 PM |
| Av400 | fjromero | Solid State | 0 | 28th April 2007 12:32 PM |
| PCB for AV400 | bigpanda | Swap Meet | 12 | 9th July 2005 05:27 AM |
| AV400 help for +-35v | aleopeldd | Solid State | 1 | 24th September 2004 05:14 AM |
| need help with AV400 pcb | jZZ | Solid State | 5 | 31st March 2004 11:06 PM |
| Page generated in 0.07305 seconds (73.14% PHP - 26.86% MySQL) with 10 queries |
