Old 9th March 2007, 03:33 PM   #1
3KFX is offline 3KFX  United States
Default Plate Amp power cutout
We (A friend and I) have a Kenwood Powered Subwoofer plate amp rated at 160 W power draw that goes into protection mode after the gain is set above ~1/4 total gain. Can anybody give us some guidance on how to find where the problem originates and what we could do to fix it?
If more information is needed, I'll try my best to get the info to you.
Old 9th March 2007, 05:02 PM   #2
XEAGLEKEEPER's Avatar
3KFX
Hello neighbor.Do you have a schematic or service manual?Have you replaced any parts(substituded) in the amp?
Dave
Ret. USAF... AKA- Avionic *** Solder slinger for hire...***
Old 9th March 2007, 06:46 PM   #3
Hello, I am the friend that 3kfx talked about up there. None of the parts have been replaced in the plate amp. We suspect that the output transistors may have issues because there is a possibly that the outputs to the speaker(+ and -) touched. I will try to post a picture soon.
Old 9th March 2007, 07:00 PM   #4
If the + and - touched,chances are the outputs are toast..
Old 9th March 2007, 08:08 PM   #5
would it be just the transisters... or could it be more?
Old 9th March 2007, 08:40 PM   #6
Hard to tell without a schematic--possibly emitter resistors also The resistors would be the larger 1,2 or 5 watt wirewound low resistance variety.They are probably located close to the output transistors. Did it blow any fuses?
Dave
Old 10th March 2007, 06:00 AM   #7
We carefully looked at all the components, 3kfx and I, and also we had another person, who has previously built simple amps and knows a decent amout about amps take a look at the components and couldn't find anything visibly burned. The resistors all looked fine. There was a tiny bulge on one of the two bigger caps. I'm not sure what that means, but he said it wasn't anything to worry about. Also, on a side note, the outputs consist of two orange (positive) wires coming from the board, and one black one. Its not related to the problem, but why the doubling up of the positive leads at the same gauge?
Old 10th March 2007, 07:45 AM   #8
When I stated outputs I was referring to the output transistors. The wires you were referring to are probably the AC wires off of the transformer. As for the resistors and output transistors they are going to have to be checked with a DMM digital multimeter.They may look OK but still be bad they need to be ohmed out(checked)
The bulge on the capacitor is not good . This is another issue that needs to be addressed.
Old 10th March 2007, 07:57 AM   #9
Just curious.Do either of you have a DMM? Do you know how to check a transistor or resistor?Can you post a couple close-up pictures or a schematic diagram of the amp?
Dave
Old 10th March 2007, 04:25 PM   #10
Sorry guys for the confusing posts, but I was logged in on an old account (3KFX - I was at school and didn't remember my user name or password, but apparently guessed the old account)... I'll be using this one from now on...
I have access to a digital multimeter, and some other basic electronics tools. A resistor I assume you check by making sure it's the stated resistance. A transistor, I don't know how to check (though I haven't had time to search Google yet). Also, if the capacitor should be of concern, how would I check that.
Does anybody have a normal testing procedure they go through? Do we first test what voltage is put out by the amp before it cuts out? Check the transistors? resistors? capacitors? What should we be looking for?
two BIB questions re inner baffle and driver cutout drec Full Range 3 23rd December 2006 02:59 AM
Lenco plinth cutout plans? fishwinker Analogue Source 5 3rd September 2006 02:11 PM
Power supply cutout argonrepublic Everything Else 0 15th March 2006 06:09 PM
Acoustic damping by cutout wood Kjetil Multi-Way 4 31st March 2004 02:06 AM
Page generated in 0.10286 seconds (76.88% PHP - 23.12% MySQL) with 10 queries
