+-70V amp needed +-70V amp needed - diyAudio
+-70V amp needed
+-70V amp needed
Old 9th March 2007, 01:21 AM   #1
hernanstafe is offline hernanstafe  Argentina
Default +-70V amp needed
I have a +-70V transformer and i need an amp to use it, cause most amps work at about +-40. The amp has to be 100w+ and i want to use it for a subwoofer. Any ideas? I saw the zeta320 but there's no pcb and it works with 60v not 70v
Old 9th March 2007, 02:58 AM   #2
GOGY-ST-HR is offline GOGY-ST-HR  Croatia
HAY!
What you think when you say "transformer +/-70 volts" AC,or DC voltage after bridge rectifier and capacitors,or just AC voltage direct on transformer before bridge rect. and caps!!?? Please be precise!
Old 9th March 2007, 02:59 AM   #3
quasi is offline quasi  Australia
quasi's Avatar
Default Are you sure about the transformer ?
Are you talking about the DC voltage of a filtered power supply or are you talking about the transformer voltage. You have expressed the voltage as DC (+70 0 -70v) and in this case there are several projects around DIY that would do the job. P:rovided the transformer is power enough you will get around 200 watts into 8 ohms.
If though your talking about the transformer voltage, 70 0 70 AC then you will end up with rails of approx +95 0 -95 volts DC. In this case you could potentially get about 380 watts into 8 ohms.
Lets us know what you got and we'll go from there.
Cheers
Quasi
Old 9th March 2007, 04:04 AM   #4
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
any idea what kind of current? for an 8 ohm amp you should have a current of 10A, or 20A for a 4 ohm amp (or stereo 8 ohm).
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 9th March 2007, 02:51 PM   #5
guys! thanks for your replies, i got +/-70V OFF THE RECTIFIER, not the transformer.
Old 9th March 2007, 05:08 PM   #6
jaycee is offline jaycee  United Kingdom
Anthony Holton's AV400 amp should fit the bill.
This delivers 400W into 4 ohms, and uses MOSFET outputs. You're going to need a big heatsink though, and plenty of capacitance. Don't bother if your transformer is any less than 600VA.
Anthony sells boards for this but you can also find the schematic floating about and make your own.
Old 9th March 2007, 05:27 PM   #7
XEAGLEKEEPER is offline XEAGLEKEEPER  United States
XEAGLEKEEPER's Avatar
ESP's P68 fits the ticket @ 500wpc
http://www.sound.westhost.com/project68.htm
I am currently building one now using a 1.0KVA toroidal and a massive heatsink
Dave
Ret. USAF... AKA- Avionic *** Solder slinger for hire...***
Old 9th March 2007, 07:30 PM   #8
taj is offline taj  Canada
taj's Avatar
Default Leach superamp?
I have a pair of similar sized transformers (maybe 3-4 volts higher). Will a Leach SuperAmp (double-barreled) amplifier work with a voltage of -+70-75? It specs +-85.
..Todd
Old 9th March 2007, 08:08 PM   #9
taj's Avatar
Here's another design which expects -+70v rails:
http://users.swing.be/edwinpaij/ampli_mosfet.htm
Anyone ever built this one? I've never heard of it before.
..Todd
Old 10th March 2007, 06:00 AM   #10
HAY!
Take the look on the nice Mr. Quasi works!
http://www.diyaudio.com/forums/showt...59#post1103559
Halelujah!
+-70V amp neededHide this!Advertise here!
Help needed ! Inter M R300 schematics needed ! alexclaire Solid State 30 9th September 2009 06:14 AM
LT1964-adj Help Needed or Part Needed lgreen Parts 2 29th June 2007 02:50 PM
PSU Help Needed ardo Power Supplies 4 26th June 2006 05:15 PM
Copyright ©1999-2017 diyAudio
