Old 9th March 2007, 01:42 AM   #1
panson_hk's Avatar
Default noise level hearing evaluation
Is it a common practice to short the input to ground of an amplifier when doing noise level hearing test? Or we via a resistor having value similar to expected source resistance? Is noting heard (hiss, hum) 1 cm from speaker an essential requirement for a solid state amplifier?
I have no problem when testing most power amp I have built. But when I put a pre-amp with its input shorted to ground, I always can hear hiss noise (no hum) from tweeter. Is my pre-amp too noisy? Or the power amp's gain too high? Residual output noise (input groundedd) of a pre-amp should be in uV range to rank its low noise?
Very low level noise on CD880 tubee Digital Source 1 24th November 2008 11:26 PM
NTE flameproof - noise level? taj Parts 4 26th August 2007 03:02 AM
Noise level swaroopvg Chip Amps 0 11th July 2006 09:24 AM
noise and or rfi supression for dimmers for evaluation tests dannymansbach Power Supplies 3 8th July 2005 08:27 PM
Page generated in 0.06499 seconds (61.70% PHP - 38.30% MySQL) with 10 queries
