Old 9th March 2007, 12:42 AM   #1
panson_hk's Avatar
Question Why no Pre-amplifier forum?
I wonder why a forum dedicated for pre-amplifier is not available. Most amplifier design books are 100 % for power amp. Is it because an active pre-amp no longer necessary? Line out from digital source is high enough to drive power amp directly with a passive pre-amp (volume control).
Old 9th March 2007, 01:16 AM   #2
sam9 is offline sam9  United States
sam9's Avatar
They are already covered under either Solid State or Tubes. Your choice.
Old 9th March 2007, 01:20 AM   #3
destroyer X's Avatar
Default Maybe because our audio sources are already pré amplified
as you already have concluded.
Almost everything you have, as audio sources, have something near 1 Volt of audio output...so...they match almost all power amplifiers...the need of pre amplifier is reduced to old turntables and the need to adjust bass and treble...and also this need is reducing as some people avoid to use, prefering to listen a flat system.
Other reasons may come.. will be interesting to read other guy's ideas about it.
In my personal use.... to compare amplifiers...to construct and compare them.... i have never used pré amplifiers, reason why i do not see interest on them...i think that each audio stage removed the better will be the sound... this is what i think about.
But i know a lot of people that use pré amplifiers and they explain that need in many different ways.
regards,
Carlos
Old 9th March 2007, 05:55 AM   #4
unclejed613's Avatar
actually there are many uses for preamps. switching between multiple sources, supplying gain and equalization for phono inputs, volume control, tone control (if that's what you want, mono/stereo switching. preamps also extend cable life, go ahead, try plugging and unplug cables every time you want to listen to a different source (with what some spend on cables per year one could pay for several preamps).
also there's tape loops for tape decks and other recording media. with modern preamp technology, distortion and noise really isn't a problem.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 9th March 2007, 05:20 PM   #5
XEAGLEKEEPER's Avatar
As per Unclejed,with addition to running multiple amplifiers
Ret. USAF... AKA- Avionic *** Solder slinger for hire...***
Constructors, have you assemble some forum amplifier, can you post it here? destroyer X Solid State 22 5th October 2005 07:19 AM
Thanks forum! mike Multi-Way 7 28th January 2003 12:08 PM
French people on the forum ? Des Français sur le forum ? frankie Introductions 19 30th December 2002 08:40 PM
Page generated in 0.09594 seconds (61.89% PHP - 38.11% MySQL) with 10 queries
