Noob Question: What is a volume buffer?
Old 8th March 2007, 06:53 PM   #1
hifimaker is offline hifimaker  United States
hifimaker's Avatar
Default Noob Question: What is a volume buffer?
I'm engaged in learning about buffer circuits. I've come across buffers called volume buffers. What are they?
Thank you!
Old 8th March 2007, 07:18 PM   #2
R.I.P.
no voltage gain. lots of current gain. high input impedance. low output impedance.
/sreten.
Old 8th March 2007, 07:59 PM   #3
KISS is offline KISS  United States
"no gain", being a gain of +1 idealy.
Old 8th March 2007, 08:05 PM   #4
hifimaker's Avatar
Thanks for the help!
-David
Old 9th March 2007, 12:57 AM   #5
vynuhl.addict is offline vynuhl.addict  Canada
vynuhl.addict's Avatar
A volume buffer is usually seen before the volue pot, it provides a fixed high impedence input thus making the load seen by your source output easier to drive by isolation from the volume pots isolation from the outside world in a sense .a sole potentiometer is an ever changing impedence based on where you set it and most standard commercial outputs are pretty wimpy on drive capability but they all will work and distort differently. I have always preferred a gain of2 buffer in all my preamp projects, while the second half after the pot is the gain block.
Colin
Old 9th March 2007, 06:16 AM   #6
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
another volume buffer is shown below. the pot acts as a volume control for the stage by changing the feedback ratio of the op amp. the advantage of this circuit is the high input impedance and low output impedance, and also that if the potentiometer fails, there will still be output (although it's probably not a good thing that the volume will be all the way up when that happens)
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 9th March 2007, 07:14 AM   #7
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Do you work for a marketing department? What will the output be if the pot fails? Rail DC?
Old 10th March 2007, 12:25 AM   #8
ReidK is offline ReidK  United States
Isn't pot failure usually an open wiper? That would indeed result in max volume and not a pinned-up output. That's why the pot is wired the way it is.
BTW, I've passed along a copy of your slur to the Marketers' Anti-Defamation League. You'll be hearing from their flying monk..., I mean, attorneys.
Reid
Old 10th March 2007, 07:15 AM   #9
analog_sa's Avatar
I won't. My pots just failed.
Old 10th March 2007, 08:26 AM   #10
Graham Maynard is offline Graham Maynard  United Kingdom
R.I.P.
Graham Maynard's Avatar
The circuit in post#6 will not reduce output below unity gain, the circuit in post#1 will !!!
Noob Question: What is a volume buffer?Hide this!Advertise here!
Simple Volume/Buffer! amplifierguru Solid State 40 24th November 2016 04:26 PM
Volume pot/buffer/optical control jonnoh Solid State 5 10th April 2010 02:37 PM
Very noob question snails07 Chip Amps 10 7th October 2008 11:42 PM
Help a noob build Pedja Rogic's J-fet buffer mattjk Chip Amps 5 29th July 2008 05:10 AM
noob I2S question p_ete2003 Digital Source 6 19th May 2004 05:51 AM
Copyright ©1999-2017 diyAudio
