Hi!, this is a preamp for guitar or bass; but it have a problem; and I can´t find it.
When I turn it on, nothing happens. This is the circuit(you can see it with Express Pcb) |
#2 |
if you can´t see it; here is the Pic
#3 |
The supply, is a regulated +15v 0 -15v.
The input is my guitar. Here is the Specifications of the Rc4558 *La fuente de tension es regulada, de +15 0 -15v. La entrada es mi guitarra. Aqui están las especificaciones del integrado Rc4558 I hope you can help me.. espero q me puedas ayudar |
#4 |
P2 is rewired
#5 |
Now the preamp work! I have Signal in the output; but with noise.
When the gain is max, the output signal is distortioned. *Ahora el Preamplificador Funciona! tengo señal a la salida; pero con ruido. Cuando la ganancia esta al máximo, la señal de salida es distorsionada. |
#6 |
Hola amigo.. has logrado un pcb para tu pre-amp? funciona?
#7 | |
Hi Doctor, the pre-amp works good; but it have noise(over 15Khz i Suppos). this is the Pcb. hola doctor, el pre-amp funciona bien, pero hay ruido (por encima de los 15 Khz supongo). Este es el Pcb. |
#8 |
and the Sch
#9 |
if someone have an opinion.... or a change for this preamp...
*Si alguno tiene una opinión..... o algun cambio para el Preamplificador.... |
#10 |
Tanks you for answer.... / gracias por responder..
my engish is terrible..!! im sorry voy a estudiar el diagrama y en cuanto repare mi agujereadora voy a tratar de ensamblarlo y si puedo quitarle el ruido te aviso, lo has empleado en algo?? |
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| Guitar Preamp = MIC Preamp = other preamp ,,are they all same? | Paswa | Solid State | 1 | 12th March 2008 05:16 PM |
| twisted pear Preamp/other suggestions for Preamp kit | LukeDuke | Chip Amps | 1 | 1st February 2008 09:57 PM |
| Electret mic preamp - will phono preamp work? | darthmullet | Analogue Source | 6 | 12th October 2007 07:32 AM |
| wiring preamp outs on a preamp | bonsai171 | Solid State | 4 | 22nd March 2004 10:13 PM |
| Page generated in 0.12749 seconds (75.63% PHP - 24.37% MySQL) with 11 queries |
