#2 |
Did it Himself
Long wiring to the gates is bad, have you included gate resistors? Try and make the wires shorter.
What decoupling have you included on the driver board and is there any on the output board/devices?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
Have you used a Zobel at the output?
Jorge |
#4 |
Yes I included the gate resistors, I will start rewiring it.
If by decoupling you mean capacitors on power rails, then yes I used the capacitors showed on the diagram. About the zobel: I tried to use it on one channel, don´t know the values right now, but after powering up with the zobel the channel got blown... |
#5 |
The zobel was 1ohm and 10nF.
#6 |
It should be more like 10ohms+100nf. 1ohm is too low.
#7 |
OK, but if I rewire the whole thing tomorrow and the oscillations don´t stop, what should I do next?
Add a capacitor(s) somewhere? Increase gate resistors? Use more decoupling? |
#8 |
you can try to use bigger c24 a c25 ,but the high frequency gain margin will be lower.
the best solution is to remake it using shorter wirings to the output transistors. |
#9 |
I rewired the amp and it is stable when nothing is connected, but it starts oscillating at cca 5Mhz, ~0.5V when I connect bare speaker cable to the output.
The cable is about 3m long and has 200pF capacitance. Any help to this? The feedback resistor is paralleled with 220pF to decrase bandwidth above 20khz, so why does it behave like this? |
#10 | |
You can use this cap in any size only if the amp is unitygainstable. Reduce this cap below 22pF or skip it. Dou have a zobel at the output? (100nf+10ohm) Without it many amplifiers start to oscillate when speakercable is connected. Mike |
| 807 AB2 oscillation maybe? | Craig405 | Tubes / Valves | 27 | 25th March 2008 10:01 PM |
| CDP Oscillation | emmasdad | Digital Source | 0 | 4th January 2006 03:54 PM |
| Oscillation | raveenvijendren | Solid State | 15 | 18th December 2005 11:16 AM |
| oscillation?? | wintermute | Solid State | 8 | 13th July 2005 01:45 PM |
| Oscillation | udip | Solid State | 5 | 31st January 2005 06:43 PM |
| Page generated in 0.09651 seconds (76.61% PHP - 23.39% MySQL) with 10 queries |
