#21 |
Continuing.
Point #4 re input diff amp degeneration resistors. Looking at the circuit again, you can probably take these up to 100 or 150 Ohms. This will reduce the loop gain . . . but that's ok if the result is you get a clean amp that does not suffer from marginal stability problems. |
#22 |
Could someone explain me how exactly does the VAS stage in this amp work?
I ask because I just found out that on one channel, which is happily working with no distortion or oscillation into 2ohms+2uF in parallel, I swapped the MJE340 from ECB connection to BCE. How is it possible that the amp still works? |
#23 |
the cascode is carrying most of the voltage across the VAS. and it swings most of the voltage when signal passes through. Are you sure MJE is inserted incorrectly? To220 and To126 have reversed lead connections. Check the PCB traces and find which voltage is on which leg. The Zener holds the cascode base at 3.9v away from supply rail voltage. This places about 3.3v across the signal To92 VAS transistor. The VAS operates as a common emitter amplifier. The cascode operates as a common base amplifier. This dual transistor arrangement is effectively two amplifiers working together in cascade mode and the odd name cascode has been invented to cover exactly this arrangement.
regards Andrew T. |
| 807 AB2 oscillation maybe? | Craig405 | Tubes / Valves | 27 | 25th March 2008 10:01 PM |
| CDP Oscillation | emmasdad | Digital Source | 0 | 4th January 2006 03:54 PM |
| Oscillation | raveenvijendren | Solid State | 15 | 18th December 2005 11:16 AM |
| oscillation?? | wintermute | Solid State | 8 | 13th July 2005 01:45 PM |
| Oscillation | udip | Solid State | 5 | 31st January 2005 06:43 PM |
| Page generated in 0.07080 seconds (71.50% PHP - 28.50% MySQL) with 10 queries |
