A powerFULL amplifier named Dirty Harry
Old 7th April 2012, 03:47 PM   #151
fotios is offline fotios  Greece
fotios's Avatar
Originally Posted by comasus View Post
Then what could be the frequency range ??
Practicaly speaking, will be the same. 20Hz to 20000Hz +/-1dB.
Don't worry so much about this, here we have to do with a PA audio power amplifier.
Best Regards FOTIS ANAGNOSTOU
Old 7th April 2012, 03:52 PM   #152
comasus is offline comasus  India
Yes sir however we cannot hear beyond 20Khz
then we cannot find change in the clarity of sound right??
Old 7th April 2012, 06:22 PM   #153
fotios's Avatar
I cannot hear beyond 8KHz
But keep in mind that PA speakers are very revealing of any difference due to high sensitivity (101 to 103dBSPL/1W/1m). In a same way, because we know that a PA power amplifier is designed to drive PA speakers, mid-high frequency area is of less importance than low frequency. Big 15 - 18" PA woofers demand lot of power to move, while mid - high compression drivers loaded with horns demand less power.
The difference is that: MJ15024-25 have Ft = 4MHz while MJ15020-21 have Ft = 20MHz in the expense of Ic = 4A. While the new MJL3281A-1302A have both Ft = 30MHz and Ic = 15A.
Old 7th April 2012, 11:38 PM   #154
JohnTubeamp is offline JohnTubeamp  Cyprus
Hi Foti, how are you doing?
I have a power amp module with 5 pairs of MJ15024/25...I tested it and it pushed out 550Wrms into 4 ohms. According to your experience,will this amplifier survive under such continuous usage?
Old 8th April 2012, 05:16 AM   #155
fotios's Avatar
Hi Yanni
Your test results:
Vrms = square root ( Prms X Load ) = sqare root ( 550 X 4 ) = 46.9Vrms.
Vpeak = Vrms X square root 2 = 46.9 X 1.414 = 66.32Vp.
Irms = Vrms / 4Ω = 46.9 / 4 = 11.72Arms
Ipeak = Irms X square root 2 = 11.72 X 1.414 = 16.57Ap
This Ip is shared among 5 output transistors, so Ip per transistor:
Ipeak = 16.57Ap / 5 = 3.314Ap per transistor.
MJ15024-25 SOA curve (Safe Operating Area) shows:
Ic = 4.5A max for Vce = 70V
Well, you are inside SOA curve by 120%. You could feel safe yet under continuous operation of amplifier for many hours in peak power. I think is not necessary to remind you that blowers are needed for such usage.
Καλο Πασχα και καλη Ανασταση!
Φωτης
Old 8th April 2012, 07:53 AM   #156
Thank you Foti for the information. Yes of course I use air force cooling for this amplifier...I don't want to cook my coffee on it....
Καλο*Πασχα*και*καλη*Ανασταση*επισης!
Γιαννης
Old 24th May 2012, 05:28 AM   #157
emmi is offline emmi  India
PCB for this amp?
Old 24th May 2012, 06:30 AM   #158
fotios's Avatar
Originally Posted by emmi View Post
PCB for this amp?
In few months. I have to finish two audio projects for which i received payment in advance. That will take me at least 4 months. Next from this i will design new, more flexible PCBs and upgraded protection circuit for Dirty Harry.
Please be patient.
Old 26th May 2012, 05:07 AM   #159
Please be patient.
Ok sir we will wait for it
Old 26th March 2013, 03:05 AM   #160
mahesh776 is offline mahesh776
Default great sound
thanks from my heart core that you gave us a design who's sound response i was searching since 2 years ,though i am not so skilled ,but i tried to make this amp.
but a problem i am facing that it heats much in spite of force cooling.i have used 1943/5200 in output as well as in place of mje15021/20.
sir i will wait for your kind suggestion.
A powerFULL amplifier named Dirty HarryHide this!Advertise here!
SPICE model of Dirty Harry fotios Solid State 6 17th July 2008 10:45 AM
