#141 |
Yea, tekko is right.
I know people that used 2SC-2SA transistors in output instead MJ15024-25 with success. |
#142 | |
if it is can i use without it but how?? Replacement for MJ15020 and MJ15021 Last edited by jacobsetti; 6th April 2012 at 05:38 PM. |
#143 | |
Replacements for MJ15020-21 (tested with success) are MJL1302A - 3281A. |
#144 |
Hi Fotios ,
Made your Amplifier long back ago, tested it up to 100-0-100 v d.c. It rocked even on 1 ohm load. I used 10 pairs of 15024-25 in output and 15022-23 in driving. Now I want to give it a try with 2sc5200 and 2sa 1943. Please guide me how many pairs I should use to get same power as 24 25 and up to what limit d.c. will be safer with sc-sa.Any more changes you suggest. regards Vedmitra Sharma |
#145 | |
Nice Amplifier, I'm just curious with this circuit. If you don't mind, in your measurement. How many voltage would be measured from Ground to base of 2SC5200/2SA1943 and Ground to base of MJ15024/Mj15025? Regards... ![]() ![]()
#146 |
#147 | |
Thank you so much for your confidence in my amplifier circuit. Wow! +/-100Vdc supply rails, that is amazing! You should get around 2 X 550Wrms/8Ω! Congratulations. Looking at the datasheet of Toshiba, 2SC5200 - 2SA1943 transistors are rated: Pcase = 150W Vce = 230V 2SC5200 / 200V 2SA1943 Ic = 15A You should keep in your mind that ONsemi (former Motorola) transistors MJ15024 - 25 are unbeatable in robustness. Toshiba are some delicate and from those i remember from CREST PA amplifiers: max +/-90Vdc (90 - 0 - 90 V) and 9 pairs in output. |
#148 |
Yes, you could do this in the cost of a small loss in high frequency response.
#149 | |
With input shorted to GND and without load in output, the voltage between the base of output transistors and GND is: +0.54Vdc at the base of each MJ15024 (NPN) and -0.54Vdc at the base of each MJ15025 (PNP). |
#150 |
| SPICE model of Dirty Harry | fotios | Solid State | 6 | 17th July 2008 10:45 AM |
