IGBT amplifiers
IGBT amplifiers
Old 15th January 2008, 08:17 AM   #41
clm811 is offline clm811  United States
clm811's Avatar
I own several old Forte Model 4's and I can say with no reservations that they continue to compete with today's best offerings.
I can agree with Mike! I've got a Soderberg-modified Forte Model4, which I'll compare to any solid state amp made today. Its combination of detail and sweetness, along with a wide, deep soundstage make it a contender -especially at the used prices you can find them for nowadays.
Just my 2 cents...
-chas
Old 16th January 2008, 05:51 AM   #42
Workhorse is offline Workhorse
Workhorse's Avatar
The amp although uses slow IGBTs, but the application requires only subwoofer use.........For Full range, we have Hi-speed IGBT as well
Old 12th August 2010, 09:00 AM   #43
celsosc is offline celsosc  Portugal
Hello, I would like to recover this older topic again.
Now with new Hi-Speed IGBT´s on the market, I was wondering if someone is using IGBT's in a H-Bridge configuration for high Power Sub-woofer amplification or even was use successful for Full-range amplification.
Old 12th August 2010, 11:09 AM   #44
jez is offline jez  United Kingdom
John Linsley Hood published a comparison of IGBT, MOSFET and BJT's when used in an identical amplifier. It was commissioned by Toshiba in order to show of their complementary IGBT's (App. note X3504)
The result was that MOSFETS had by far the lowest distortion followed by BJT's and then IGBT's. The only area that the IGBT's won was in maximum output power at clipping.
Old 12th August 2010, 11:46 AM   #45
Hello jez,
I was thinking IGBT's specific in class D operation. The new WARP2 devices from IR can handle switching up to 150khz. Having this devices in a full bridge operation would give massive output power.
Maybe I should post in the Class-D subsection.
Old 29th September 2010, 10:12 AM   #46
milosz is offline milosz  United States
Default IGBT amp: Forte 4a
I have a Forte 4a with the Soderburg mods (black gate caps, and I think different (faster) rectifiers, and better output lugs.)
It sounds GREAT on my Quad ESL-57's, best solid-state amp I've heard on them.
The Forte 4a is easily as musical as any modern SS amp I've heard, and I've gotten to audition quite a few of the "famous names" and the "obscure niche amps" in this system, which is equipped with a level-matching A/B power amp comparison switch. I'm sure Nelson Pass is right and part-matching must be a pain, but there's something about the sound that is just "right." Maybe the harmonic spectra? I dunno.
Best $800 I ever spent, that forte 4a. It made a friend who just dumped $15,000 into some Uber-amp cry when he heard the Forte 4a sounding clearly better.
Old 29th September 2010, 11:24 AM   #47
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Originally Posted by Piersma View Post
This IGBT amplfier was published some years ago by Elektor.
The specs of this amplifier were quite good according to measurements done by Elektor.
best regards,
Piersma
Not only here some guy's claim, IGBT's are first choice for audio output power stages.
Check out in this case also this thread:
http://www.diyaudio.com/forums/solid...s-cfb-amp.html
Who can post an overview of currently available types suited for this application?
Old 26th August 2015, 07:27 AM   #48
LiquidMids is offline LiquidMids
Banned
Default Matching..
I do not care much for trying to match combined multi-devices like this or the MT-200 transistor.. On top of that, I have yet to hear a good sounding amp that uses MT-200. I'm just not a fan of combined packages at all.
It seems this just adds extra difficulty to an already complicated process.
More likely to drift off spec too..
Now for budged constraints and compromises, that is up to the user what is a good deal.
I shoot for dead accuracy and reliability.
Old 26th August 2015, 08:26 AM   #49
ilimzn is offline ilimzn  Croatia
MT-200 devices are single die in 99.9% of all cases. There is nothing 'combined' in them?!
Old 28th August 2015, 06:17 PM   #50
Banned
Default MT-200
You are wrong. MT-200 transistors can test good but still be bad. I went through this with a HK-3490 receiver. They are like two transistors hooked together inside, and they can pass a diode check and still be bad.
These receivers sound grainy just like a Sony receiver I had that used these same type of outputs.
I understand that there may be variations to this type of package that are single die, but I know that some common ones I have fixed were darlington style like a 2SD2401 . A quick google search will show many part numbers for these that are darlingtons inside. Just search MT-200 Darlington.
.. Didn't mean to get off topic here.. The IGBT isn't exactly the same thing inside.
IGBT amplifiersHide this!Advertise here!
Has somebody used IGBT in power amp boske Solid State 34 7th September 2016 04:56 PM
IGBT Still Alive Stee Solid State 7 2nd October 2008 09:48 PM
H-bridge IGBT speakerguy79 Solid State 0 20th October 2006 11:42 PM
IGBT's for sale... jazzpeter65 Parts 0 9th February 2004 06:57 PM
