Old 3rd March 2007, 04:24 AM   #1
ben goh is offline ben goh  Singapore
Send a message via AIM to ben goh Send a message via Yahoo to ben goh
Default Variac
Hi
Can anybody advise me on this.
I want to put a thermistor on the ac line connecting a 2 KVA
variac to suppress the surge, will it work?
Old 3rd March 2007, 07:22 AM   #2
Default Whats your application ?
You want to use a variac and thermistor ? Are you sure you don't mean a Varistor ? These are often used for surge limiting.
They are also referred to as MOV or Metal Oxide Varistor.
They go across the AC line and are rated for the working voltage (120-240 vac) and have a clamp voltage above this working voltage.
http://www.littelfuse.com/varistor.html
What are you trying to do ? Maybe I can point you in the right direction..
Old 3rd March 2007, 07:22 AM   #3
Default Woops
Sorry, I just realized what your doing.. My bad.. See this post
http://www.diyaudio.com/forums/showt...90#post1148590
Old 3rd March 2007, 02:18 PM   #4
myhrrhleine's Avatar
When I use a Variac, I turn up the voltage slowly, watching the amp meter.
So, no surges.
Would this work for you?
Just because you can't hear it doesn't mean no one can.
Old 4th March 2007, 05:32 AM   #5
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
The own variac produces the surge when it is plugged, and it may be strong enough to trip the circuit breaker
I use to feel like the small child in The Emperor's New Clothes tale
Old 4th March 2007, 06:14 AM   #6
Warp Engineer
On Holiday
AudioFreak's Avatar
And I wouldn't want the amp connected to the speakers while bringing up the voltage on a Variac.... Some amps don't operate very well until they get a minimum operating voltage and could potentially damage your speakers.
- Dan
Old 4th March 2007, 06:56 AM   #7
fotios is offline fotios  Greece
fotios's Avatar
Make this one DIY power supply with variac and many auxiliaries to get a full control.
Old 4th March 2007, 05:51 PM   #8
I never noticed that on any of the variacs I used.
When the secondary is set for zero volts,
How much surge current have you noticed?
It must be a huge surge to trip a breaker.
Old 4th March 2007, 05:53 PM   #9
I agree.
Hopefully one would use load resistors.
Old 5th March 2007, 02:17 AM   #10
Hi
Thanks for the reply and advises
The problem is that without connecting the secondary to any load.
The breaker will trip occasionally when I turn it on. I do not want
to wear out the breaker. It is a 2 KVA china made variac.
DIY Variac Tyimo Solid State 4 6th October 2007 11:18 AM
FS 10A variac woody Swap Meet 8 16th May 2007 04:38 AM
Using a variac. anders.a Parts 3 4th April 2006 07:12 PM
Variac? Scribble Pass Labs 16 29th July 2004 02:12 AM
Page generated in 0.11504 seconds (71.11% PHP - 28.89% MySQL) with 11 queries
