Do not search without reason. See the photograph below; four Lead Acid rechargeable batteries (each of 12V / 7Ah, from those that are used in UPS or alarm units) can offer a split power supply of +/- 24Volts without any ripple noise. With such supply can operate for 3 to 4 hours a preamplifier who consumes 150 W approximately. Afterwards the batteries it should recharged with a 1 hour fast charger. What a story and this, ha? It concerns however those that seek the absolute solution. Moreover it costs as much as one good stabilized power supply. I believe however that the benefits that it offers this solution are very much compared to the labour that it requires.
#2 |
Here is the proof. See in the oscilogram the noise floor of my discrete preamp module output; and with the input opened! (not shorted to ground). The output noise is just about 73 ėVolts!
#3 |
I have seen other sites compare batteries to active PSUs and always the batteries came out looking pretty poorly.
regards Andrew T. |
#4 | |
#5 | |
150W for a preamp?... I tend to use fairly high rails and high current for the preamps I build, but I find it difficult to use more than a third of that. Incidentally, the use of batteries in audio circuits hardly qualifies as news--it's been done for years. The merits (or lack thereof) are already known. Grey |
#6 |
How to assure that both rails have the equal discharge rate during usage????
#7 | |
Regards Fotios Anagnostou |
#8 | |
#9 |
I want to make a clarification. Sure the subject of supplying by batteries is more encyclopaedic. I write this in order to it does not take error conclusions some new person in the audio constructions. Moreover and me i use electric power supply from the mains in my preamplifier. Experimental i only use from time to time the batteries because they are not practices. What that has importance however, is this oscilogram shows the complete absence of noise in output, in order to we conceive how many it influences the ripple of power supply the sound quality. Also when the batteries begin to discharge, while the appliance still operates, is decreased dramatically his sound quality. The circuit is designed and measured in order to operate with constant supply voltage. When it falls under a limit, as we say from +/- 26 Volts in +/- 24 Volts together it falls also the transient response while are increased all kinds of distortion. These with regard to other preamplifiers. Mine has a limit at +/- 20 Volts so it begins to distort or it presents D.C. offset at output. In any case the experiments do not harm. All these in order to us close this subject here.
Fotios Anagnostou |
#10 |
It seems to me the major problem with conventional active power supplies is the wideband RFI generated by the sharp current pulses and diode switching noise of capacitor smoothed diode bridge circuits.
Batteries do not suffer from this problem but can have higher transient noise levels than active PSUs when called on to supply current. Is not the simple answer to regulate battery power supplies with high performance low noise regulators? Gopher |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| Power Supply for Preamplifier | skogs | Solid State | 15 | 15th June 2007 01:16 PM |
| FS : Battery Supply Tube Preamplifier (12V SMPS to 275V) | ANALOG GUY | Swap Meet | 0 | 30th October 2006 08:38 AM |
| selling high current power supply for power amps. | ericpeters | Swap Meet | 0 | 14th January 2005 02:21 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
| Page generated in 0.19121 seconds (52.70% PHP - 47.30% MySQL) with 11 queries |
