Old 1st March 2007, 10:56 AM   #1
geminni is offline geminni  Yugoslavia
Default Microphone "whistel" canceler schematic need!
I'm not shure if that is the corect name for the thing i would like to make.
Is there something that can protect speakers and amlifier from those nasty whistles when microphone gets near loudspeaker?
Old 1st March 2007, 11:40 AM   #2
Dag is offline Dag  Sweden
Dag's Avatar
This is not possible. (Hm..just because I say so someone will have a solution....but that's ok I guess) The whistel sound is caused by the delay in the microphone-electronics-speaker-microphone loop. If you filter the whistel out you will also filter out the audiosignal.
Old 1st March 2007, 11:47 AM   #3
megajocke's Avatar
http://www.behringer.com/DSP1124P/index.cfm?lang=ENG
It uses some kind of search algorithm that controls a parametric equalizer
Old 1st March 2007, 11:50 AM   #4
pinkmouse's Avatar
These work pretty well. Behringer do one too, but I have never used theirs. For diy, the only thing you can do easily is a high Q swept parametric.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 1st March 2007, 12:30 PM   #5
The oldest versions of feedback-killers (or feedback eliminators) used frequency shifters that shifted the whole audio spectrum up or down. The frequency-shift was between some tenths of a Hz up to ca 20 Hz.
The working principle was similar to the so called phase method for SSB.
Charles
Old 1st March 2007, 01:59 PM   #6
I had the idea about that high Q. Couple years ago me and my friend were doing some experiment with mic and 3-way speaker. Each speaker had its "own" wistle frequency. I will have to do same test now to determine if this is true. Back then we were just beginers and did not pay atention on details. If the test shows that there is one frequency for each driver, in my case for 2-way PA speaker, then i would hace to build 2 Q filters that will choke those 2 frequencies.
Maybe i'm to paranoic about these stuff and i'm asking too much for total amplifier protection
Old 1st March 2007, 02:02 PM   #7
pinkmouse's Avatar
Make the EQ swept. Feedback changes with speaker positioning and the room.
Al
Old 1st March 2007, 02:03 PM   #8
Forgot to add that i think mic is allso a blame for the frequency. Maybe diferent mic will give diferent frequency so there will be need for the variable frequency
Old 1st March 2007, 02:05 PM   #9
pinkmouse's Avatar
Indeed.
Al
Old 1st March 2007, 02:35 PM   #10
imix500 is offline imix500  United States
Proud Union Member
imix500's Avatar
Correct system eq and speaker placement will help a lot here. Also, you can try backing the system up to the mics with system delay- this will help a bit too. The "feedback eliminators" work ok, but they can be too aggressive and filter out audio that is not feedback.
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
schematic variation and sim results of Pass "X" series US pat 5376899 tiefbassuebertr Pass Labs 13 30th July 2009 08:33 PM
"Plasma" microphone - physicist's help desired ... gentlevoice Everything Else 4 15th January 2008 05:46 PM
Microphone "static" theavguy Everything Else 2 12th January 2007 09:53 AM
power supply schematic with a 6080 used as a "pass tube" jarthel Tubes / Valves 1 27th May 2006 03:41 PM
Page generated in 0.13176 seconds (70.44% PHP - 29.56% MySQL) with 11 queries
