hey all,
i have an idea... i'm thinking of an amp which has both solid state as well as tubes. okay...it goes like this, i want o use the tubes to run the tweeters and mid range but i wan the solid state to drive the woofer (low end freq ; i.e bass). to put all this in one box, of course e speaker wud have to be bi-wired. the challenge wud be making this for a 2 way speaker. a 3 way speaker wud be easier i guess.. i've read e bi-amping articles but they dont really split the output signals like this. so guys, any ideas? I'm running a pair of MISSION 764i speakers,89db @ 8ohm. anything upwards of 100v shud be enuf to power these guys. they do suck a lot of juice... rgds. |
#2 |
Did it Himself
If the speakers are 2-way then you can only use 2 amps per channel to drive them. So you would run the tweeters off the valve amp and the woofers off the transistor amp.
If it was a 3-way speaker then you could use another valve amp for the mid.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
so wat ur saying is bi-amping is it?
i was thinking of everything in one box.. 1 amps in one box.. is there a circuit diagram for this? |
#4 |
Did it Himself
What box the amps are in is not really relevant. Put them where you want.
You will either use the existing speaker passive crossover, or make a new electronic active crossover. What remains is that you can't use both a transistor and valve amp on one drive unit, they must drive different drive units.
| Tube hybrid - split from CA340A thread | MJL21193 | Chip Amps | 21 | 14th January 2009 07:44 PM |
| Page generated in 0.06623 seconds (70.66% PHP - 29.34% MySQL) with 10 queries |
