Old 4th March 2007, 09:41 AM   #21
XEAGLEKEEPER's Avatar
I'm a Ferrari man ever since my countach went belly-up.LOL
Ret. USAF... AKA- Avionic *** Solder slinger for hire...***
Old 4th March 2007, 09:47 AM   #22
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally posted by pinkmouse
to pull a caravan, or indeed, a truck to pop down to your yacht
Valentino Balboni will disagree.
Looks like Sponge Bob has killed another thread.
Old 4th March 2007, 10:21 AM   #23
mjraudio's Avatar
Originally posted by XEAGLEKEEPER
mjraudio
Not to many Sigur Ros fans.My wife is Icelandic and she can't stand sigur ros.I like her stuff. it helps if you can understand icelandic
@XEAGLEKEEPER: Yeah Sigur Ros is great because there is a lot of ambience in the tracks and they tend to be very progressive in nature. I have their album Takk and it has given me moments of nirvana during my listening sessions.
There is no "best" resistor or cap...
@All: Back to the discussion at hand...I do think that the high end capacitor market contains much hype and marketing, however, there definitely is theory behind many pricey capacitors. The Mundorf Silver/Gold axial caps seem to be among the top designs in theory. Silver and Gold are excellent conductors and thus using them WITHIN components and not just as solder or wire should yield improvement in any circuit. Now, whether these improvements are measurable depends on the accuracy and sensitivity of your measurement equipment. And whether those improvements are audible is subjective to each listener's ears, and they most certainly differ from the accuracy of scientific testing.
I have decided to buy surplus NPTM metalized polypropylene 4.7uF 400VDC/250VAC axial leaded capacitors from Steve over at apexjr.com.
At $1 a piece, I would argue that these are the "best" VALUE
I'm going to be using 1 of these in each of my monobloc amps for input filters (DC blocking), and then 2 of these for each receptacle in my custom DIY power "filter" box.
--MJR
MJR AUDIO My System
Old 4th March 2007, 10:34 AM   #24
jackinnj's Avatar
I'd rather have a Zamboni than a Balboni.
You can find polystyrene from US manufactures without too much difficulty -- I have soldered these with my Hako with no difficulty -- i found that when I built the Super Oscillator substituting polystyrenes for polyethylene made it easier to "go".
Old 4th March 2007, 11:01 AM   #25
MikeB is offline MikeB  Germany
MikeB's Avatar
Gold beeing an excellent conductor is another highend fairy tale...
http://en.wikipedia.org/wiki/Electri..._resistivities
The difference between Gold and Aluminium is minimal.
Using gold in electronics does only make sense when making contacts, because it does not oxidize. Any other use appears to me as simply expensive hype.
Even the thermal conductivity of gold is not excellent.
Mike
Old 4th March 2007, 11:51 AM   #26
No Jack, you just want the Zamboni stock.
Merely going for high priced/reputation components is no garantee for a positive outcome, just a positive to empty your wallet.
Old 4th March 2007, 05:20 PM   #27
mjraudio's Avatar
Mike
Mike, thanks for the information. This is quite interesting...it seems as if silver plated copper would be the best solution. Does Silver oxidize?
What are you thoughts on the Mundorf Silver/Oil capacitor?
But gold looks so pretty! hehe
--MJR
MJR AUDIO My System
Old 4th March 2007, 05:33 PM   #28
MikeB's Avatar
Yes, gold looks pretty...
Silver also "oxidizes" (becomes black because of sulfur in the air, afaik)
Gold plated copper should last for "ever"...
From what i have heard/understood, the silver/oil caps should be quite the best. But, its not only the materials, the construction also counts. Slitfoils for example sounds interesting, the metal foil is sliced to reduce eddy currents.
Mike
Old 4th March 2007, 07:12 PM   #29
Sulphur(sulphuric acid) is the only element that harms silver.
Capacitor sound quality, silver mica in particular klitgt Parts 14 23rd September 2005 04:54 PM
Capacitor sound ermes Multi-Way 9 2nd November 2004 05:19 AM
Capacitor sound? Skorpio Pass Labs 1 28th March 2004 06:08 PM
Capacitor sound Praise! Parts 17 18th December 2003 12:43 PM
Capacitor Sound Quality fmak Solid State 17 27th June 2002 07:19 AM
Page generated in 0.22460 seconds (47.32% PHP - 52.68% MySQL) with 11 queries
