Old 25th March 2009, 08:47 PM   #21
dkbb12 is offline dkbb12  United States
Default another VSP Labs amp owner
I own one of these, bought it new in 1981. It was gradually deteriorating for years, finally blew last year (taking 2 woofers with it...). Are there any CURRENT schematics available? Would love to find someone who can bring it back to life. It was a great amp, though it did run hot. ~ Dan
Old 26th March 2009, 03:57 AM   #22
jbol is offline jbol  United States
considering that there was some damage to one channel including the pcb's, AND the parts were expensive, AND the FETs were subject to degradation, I decided that I got a good deal on a big power supply and massive heat sinks and am looking to use some diy circuitry instead of repairing it. The only circuit diagrams I am aware of are those listed in the thread but you can always google. Yes, the one channel did sound nice.
Old 26th March 2009, 07:06 PM   #23
bear's Avatar
the links to the pdf schematics no longer function...fyi.
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Old 26th March 2009, 08:55 PM   #24
If I can find my downloaded files I will email them to you
Old 9th July 2009, 04:42 PM   #25
gmann44 is offline gmann44  United States
Default VSP Amps
I met the owner back in 81 through a friend of mine that worked there. At that time the company was based in Ann Arbor MI.
I was very impressed with which the equipment produced such a clean and warm sound. However at the time, after being on for a while under a rather lite load, I felt the heatsinks and thought, man them are hot!
In theory I thought that this thing was overheating but still sounded good. So then began to think that this was normal.
But now 28 years later I have come to think my theory was indeed correct. After seeing the posted .jpegs, I feel these Amps were 1. Being driven too hard even at low volume. 2. Were designed in a way to produce clean sound that a tube amp would deliver.
I remember talking with Juan, and his comment was to design with the power and feel of a tube amp.
Don't get me wrong, I thought they were a decent amp but poorly designed in regards to lasting. Semiconductors can only last so long under that type of driven load!
Old 9th July 2009, 11:18 PM   #26
djk is offline djk
djk's Avatar
6550s in an Audio Research D75 that is run hard last about 3~6 months, years from these FET amps seems OK to me.
Maybe after 10 years you should invest in new outputs (I know I do whenever there is a failure in one channel after a unit has been in the field over a few months. I repair the damged channel, and replace outputs and drivers on the un-damaged channel. If it is over 10 years old I replace all the small electrolytics too).
Candidates for the Darwin Award should not read this author.
Old 10th July 2009, 03:43 AM   #27
I do know that these amps, and others like it do run hot. However after looking at the posted pics earlier, I did notice that a connector and one circuit board did have serious heating problems. Not saying that the circuits are of poor design, but more so in dealing with the heat! It's been a long time since I have seen these units. I now seem to think that if the cabinet had a different design, and a cooling fan, that the problem could have been eliminated.
Old 24th December 2009, 06:27 AM   #28
Bhu108 is offline Bhu108  United States
Default what did you find out about VSP Labs?
I am interested in what you found out about your VSP Labs Trans Mos amplifier
Old 4th May 2012, 09:48 PM   #29
DARCOMP is offline DARCOMP  United States
DARCOMP's Avatar
Unhappy Link does not work--website dead please read
Originally Posted by TomWaits View Post
Here is a PDF containing a working production version of the VSP Labs Transmos 150.
Lots more work to do but I see a full restoration coming my way and if I'm lucky there will be tweaks. Any thoughts from the DIY folks here? I'd love to hear your impressions of this circuit!
Hello Tom
this link unfortunately NO LONGER WORK as it seems the website is defunct....I'm also the proud owner of the pristine TRANS MOS but not the gold version and am affraid to power her up before checking the voltages biases etc without the loads...As you can tell i dont have much confidence in the FUSES (if any) and i do not want to burn any speaker drivers...FYI previous owner drove very unstable and demanding THIELs 3600 with it and only sold it because he purchased a monster AMPZILLA dirt cheap...any info would be appreciated--primarily working schemat in PDF no longer avail...BTW did you get your unit going yet,,,THNX for posting all other stuff re. this dinasourus...Best of luck 2 y'a
how do I use this trans? whatsnext Solid State 5 10th September 2006 11:48 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
P3A amplifier output trans and Prob Hitz Solid State 2 13th January 2004 06:14 PM
Pot-Trans in a DAC Antonio Tucci Digital Source 4 27th May 2002 11:59 PM
Pass Labs XA200 amplifier GRollins Pass Labs 15 27th March 2002 08:23 PM
Page generated in 0.13310 seconds (68.72% PHP - 31.28% MySQL) with 11 queries
