#21 | |
Regards Fotios |
#22 |
i have built a voltage divider to use the soundcard to measure higher voltages than a soundcard can normally handle. as far as the bandwidth issue, i still have a hitachi scope and function generator to fall back on for things outside the bandwidth of the PC. i will also probably need a better soundcard for THD20 measurements. but for basic in-band measurements such as THD1 and 20-20k freq response, phase, etc... measurements, the PC is perfect. the only thing i could want in addition is some way of viewing the distortion residual signal so i could use the pc for setting output bias and troubleshooting nonlinearities (pc audio software writers please take note......)....
i have a copy of spectrum lab by DL4HF, which has configurable signal processing, and i might try to configure a "diff amp" section to perform the required subtraction and yield a distortion residual. if i'm successful i will upload the config file for the configurable dsp, as well as instructions for using it.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net spammer trap: http://www1284177414881.v-dc.net/ |
| Opinions from amplifier analysers on these amp circuits | georgehifi | Solid State | 10 | 11th April 2007 02:56 AM |
| Spectrum Analysis Spectrum of JX92s | keladrin | Full Range | 2 | 26th May 2006 02:10 PM |
| proposed 833 design | James D. | Tubes / Valves | 0 | 25th March 2004 12:42 PM |
| Page generated in 0.11002 seconds (65.41% PHP - 34.59% MySQL) with 10 queries |
