#21 |
Its very good to see the posts back in this thread, Graham thanks very much, its your humble effort...
Thanks, Hugh for this kind act.... Its a surprise to see the miracles of nature..and again its amazing that we have just Rediscovered Carlos once again...... Carlos could we have some more of your younger fotos too....just for refreshing the environment a bit more..... ![]() Truly Unbelievable thats Carlos isn't it! regards, Kanwar
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
#22 |
Am I in the right thread for the technical bits?
There is a heck of non topic in here hiding much of any use.
regards Andrew T. |
#23 | |
I agree a bit with you AndrewT But then again it is Graham's Topic ( with an interesting amp, as usual! ) As long Topic Starter does not mind and people are not disrespectful there should not be problems. I wouldn't have wanted to miss that 'copy of carlos man'. It is remarkable.But remember, it is the INSIDE that counts. And even if that man may be nice it is no way he can replace Carlos, for real. Nobody Can Regards lineup
lineup |
#24 |
Hi Andrew,
Yes - right place - real people. Just did a sim to check currents, etc. Input transistors - 700uA Output transistors - 53mA Source mirrors - 3.3mA Vbe for input transistor ~ 0.65V (for upper half the emitter is -ve) voltage across 470 resistors ~ 1.2V ( +ve wrt emitter ) thus output bias (22R) ~ 1.1V ~ 53mA (total both halves) |
#25 |
Hi Graham,
now I begin to see. The main input bias passes through the 22r. The bias controllers are trimming the voltage on the first input Qs to adjust the output bias to the desired result. Confusion gone. Thanks.
regards Andrew T. |
| Convert Line Level to Electric Guitar Level | miallen | Solid State | 4 | 16th May 2010 01:22 PM |
| speaker level input vs line level question | crippledchicken | Subwoofers | 4 | 17th July 2007 03:36 AM |
| lesser of two evils, high level -> line level, digital volume control | mazurek | Solid State | 3 | 19th November 2006 12:25 AM |
| how to bring down line level signal to preamplifier level | deji | Solid State | 15 | 15th April 2004 04:13 PM |
| Page generated in 0.11308 seconds (69.92% PHP - 30.08% MySQL) with 11 queries |
