Old 25th February 2007, 11:07 AM   #11
Nrik is offline Nrik  Denmark
Regarding the wish for not attenuating the input signal, ofcourse you should go for the highest practically possible Zin.
BUT: If you want to ensure perfect transmission of the signal from the source - to the amp , you'd better look into how the professionals do it.
A low Zin (600ohms) gives you some advantages. Of course you need the output of the preamp to be able to cope with it, and you might experience some attenuation, especially if the output impedance of the preamp is correctly matched (not nescesarily 0 ohms). But noise pickup, cable length, and cable quality is now much smaller issues.
If you optimise your outputs and inputs for perfect transmission, you would not be able to hear any difference between standard supplied RCA cables and expensive 'snake-oil' cables.
Are the results of your experiments pointing in this direction Fotios?
Old 25th February 2007, 11:34 AM   #12
diyAudio Moderator Emeritus
Hi, Piercarlo,
Thanks You got URL that I can read on "output impedance"? I've googled, but still not found it.
Back to the original question. DartZeel (based on the papers on his website) seems uses no Rg resistor on its input.
Old 25th February 2007, 11:59 AM   #13
fotios is offline fotios  Greece
fotios's Avatar
Default Johnson or Niquist noise and the Zin
Every amplifier has an output, even with no signal input. An output of this type caused from the noise which reduces the performance of whole amplifier. Especially the noise developed at the input where the signal is smallest from the other stages of amplifier seems to be the main cause for the total noise developed in a multistage amplification circuit. Any unforeseen current that throws from one part of the circuit to another can be referred as noise. These currents caused usually from the distributed inductance or capacitance on the different stages of the amplifier which allows an unwanted coupling between them. An example is the power supply variations which coupled to the input stage if there is not careful shielding. Also a careless design of PCB such as corners on the copper rails of the board can cause unwanted capacitance.
An unwanted inductance can developed due to without reason length and meanders of the copper rails on the board. Certainly these can avoided with a careful design of PCB. But there are other types of noise caused from the passive and active elements of the circuit. These noises are fundamental and owed to the physical structure of the elements. In a resistor, due to thermal energy that contains, there is a continuous motion of electrons. And this motion fluctuates with time developing a small current across the resistor. Of course, if not applied an external voltage at the terminals of this, current finally average to zero. But the variations around this average of current produce unforeseen noise. If the thermal energy increases in the resistor, as a consequence there is an increase in the noise produced. This thermal noise is known as Johnson noise and some times as Niquist noise and described by the equation in the attached file.
k is the Boltzman’s constant, T is the ambient temperature, R is the resistor value and Äf is the frequency bandwidth. Thus careful amplifier design call for minimizing R and limiting the bandwidth Äf only to the needed range. As you understand, this is of big importance so for the choice of amplifier Zin what as for the determination of the closed loop gain. The higher Zin make the amplifier an easy load to driven from whichever preamplifier. From the other hand, some limitation of Zin needed to avoid the increase of Johnson noise in the input. In order to we stop here the theoretical analysis and we pass in more practical subjects, I will report the conclusions from my experiments. An intermediate value of Zin at 50KÙ satisfies also the two requirements. From my trials, even preamplifiers with very low output level (in other words with relatively high Zout) can easily drive such load. From the other hand, the Johnson noise touches just the acceptable limits and this happens in frequencies above 100 KHz.A Zin about 100KÙ while it appears as more ideal, practically does not offer nothing more as load, while on the contrary the Johnson noise is increased. In amplifiers with tubes without fail it will pass unnoticed. In solid state amplifier however, it will decrease the S/N ratio in level that will be heared. A low pass filter around 100 KHz also needed as front end circuit before the differential amplifier input. And a high pass filter around 10Hz needed in the feedback loop. Thus the frequency bandwidth limited from 10 to 100000 Hz. In my amplifier, I have made one important but also controversial intervention as it will be proved by the expected replies – as happened moreover and in my thread “ Zobel network corrections ” before –. I removed the RC low pass filter of 100 KHz from the input, between the collectors of the long tailed pair. And i changed it from parallel to series. I had an idea for this, and it was proved that it functioned well in practice. Curious is that it operates better with a corner frequency of 250 KHz. Without i am sure, i have the impression that it is related with the two resistors, shunt and series, at the bases of long tailed pair. In any case it serves his aim.
Best Regards FOTIS ANAGNOSTOU
Direct Contact: eal@dra.forthnet.gr
Old 25th February 2007, 03:14 PM   #14
anatech is offline anatech  Canada
anatech's Avatar
Hi fotios,
Yes, in an idealized sense. Practically speaking, most consumer products are not designed well enough to take advantage and will not come close to an ideal noise performance. Tubes have other issues again. They also have some advantages.
What it all comes down to is a series of tradeoffs in equipment design. You are in a position to optimize the parameters you deem most important - that's good. I would only question someone who blindly optimizes one parameter without considering the others.
You can design an amplifier with a 1 Meg input impedance that is driven with a 1 ohm source impedance. This will "short" your johnson noise to ground. Let's not get into cables please!
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 25th February 2007, 08:11 PM   #15
Originally posted by lumanauw
Hi, Piercarlo,
If you can't find anything on web, the topic is just taught in introductory courses of analog electronic. Pheraps finding a college textbook on analog electronic may be more useful than googling. IMHO.
For your quesition: Rg resistor, evident of hidden exist always in all practical circuits.
H
Piercarlo
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.11350 seconds (70.46% PHP - 29.54% MySQL) with 11 queries
