I have the classic scenario: Old SS amp with a faulty channel (v quite, but sitll sound coming from it). It's a Leak Stereo 70 integrated amp. I've traced the fault to one of the preamp circuit boards. Now how do I begin tracing the faulty componet? It's resistors, capacitors and a couple of little other components, not sure what they are. Anyone got some thoughts? Also, there's a higgh pitched whine that increased with volume. It's inaudible under music though. Would anyone be able to hazard a guess over what could be causing this? Thanks Harry |
#2 | |
Magneto the Gravity Man
Does the fault ''change channels'' when you swap ?? Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#3 |
yes it does, that's how i traced it to the preamp board
so where to now if you don't mind me asking? |
#4 |
Considering the age of it, and if parts were never replaced before, if I were you, replace ALL the electrolytic capacitors with modern compatible parts for a start. At least that'll give it a new lease of life, lessen trouble in future, mandatory if its more than 20 years old or with a doubtful service history.
If you need a copy of the manual/schematic/layout, message me. I'll gladly let you have it. |
#5 |
Save yourself from the trouble. Here's a link to it:
http://home.vicnet.net.au/~vic3d/aud...ctStereo70.gif |
#6 |
HI.
for a start, I would use a 'calibrated finger' on the bass/treble control contacts and compare the volume of the resulting hum between good and bad channels. A better method would be to play a cd, and use a probe - wire plus cap- between the hot end of the vol and the input progressively working back until the sound fades or disappears. Andy
#7 |
Yes I generally agree with the capacitors being at fault I have had to replace quite a few of these during my previous life as an audio engineer !
To second it I would also measure the collector voltages on all the transistors as I have had a few of these go open circuit re the base emitter junction. Never my favourite amplifier but none the less worth restoring regards Trev |
#8 |
As Trev says about the transistors. In particular T7 is stressed since it is rated at 65V and the supply is 75V! Mind you T7 is not on the pre-amp board so it cannot be that. Love those old transistor symbols in the circuit diagram
#9 |
Hi harry
i have a pre amp pcb i think its ok and its yours for free if you want it good luck jim |
#10 |
Brilliant Jim, I'd love it!
I don't really have time to get to London at the moment though. Is there any chance you could drop it in the post? I could send you a paypal/cheque/give some money to charity... Thanks a lot, these forums can be so fantastic at connecting people! |
| LEAK stereo 70 cutting out | Minimuslover7 | Solid State | 10 | 24th August 2009 04:56 PM |
| Leak Stereo 20 clone? possibly with 6V6? | bikehorn | Tubes / Valves | 26 | 29th March 2007 01:52 AM |
| Leak Stereo 20 questions | Johan Potgieter | Tubes / Valves | 23 | 30th April 2006 11:57 PM |
| Just bought a leak stereo 20 (pics!) | SHiFTY | Tubes / Valves | 4 | 11th January 2005 06:18 PM |
| Mods on leak stereo 20 | bronto64 | Tubes / Valves | 22 | 26th April 2004 08:27 PM |
| Page generated in 0.14295 seconds (70.63% PHP - 29.37% MySQL) with 11 queries |
