Current sink, anyone studied lowest noise?
Old 22nd February 2007, 09:24 PM   #1
stevebeccue is offline stevebeccue  United States
Default Current sink, anyone studied lowest noise?
It is common to have a current sink (or source) biasing the long tail pair. Has anyone studied the lowest noise method in the 1ma range? I've seen two NPN's, LED biasing and NPN, and of course, a degenerated JFET. Has oneone made the alternatives and measured (or simulated) the lowest noise solution?
Thanks for comments,
Steve
Steve Beccue
Old 25th February 2007, 06:08 PM   #2
Chucko is offline Chucko
My guess is that the lowest noise would be from a bipolar transistor with a small emitter resistor, biased by the base-emitter junction of another bipolar transistor at high current.
I would also guess that the effects of common-mode current noise in a differential stage would be reduced significantly by a current mirror load.
Old 25th February 2007, 08:08 PM   #3
normally only the high gain of a BJT input LTP allows emitter de-generation.
Adding emitter de-generation adds noise.
Increasing the feedback resistor values increases the noise.
Allowing supply rail noise through to the output (poor PSSR) increases the noise.
Usually decreasing Rs decreases noise and increasing LTP tail current allows lower value of Rs to better suit low noise.
If I have got any of this wrong please correct my errors.
regards Andrew T.
Old 26th February 2007, 12:09 AM   #4
jcx is offline jcx  United States
http://www.national.com/an/AN/AN-222.pdf is a good tutorial on bjt noise limits
for a low noise current souce/sink the "best" approach is the highest V, quietest Vsource you can afford, if just hanging a big R from that Vsource doesn't give you high enough impedance then you have to add the transistor/current sense resistor which adds a little of the transistor's Vbe voltage noise - but less with higher base voltage
higher degeneration (from higher value current sense emitter resistor) reduces transistor noise contributions to the output noise current
In a diff pair tail current source the added noise from even a noisey ccs can be small if the output is well balanced by a collector current mirror (with large enough degeneration R) or a differential second stage or VAS - since the noise current equally divides in a balanced diff pair, it differences out in the differential output
Current sink, anyone studied lowest noise?Hide this!Advertise here!
Lowest noise and distortion Chip Anders_denmark Chip Amps 15 16th June 2006 03:03 PM
Which is the lowest noise FET? Young Solid State 10 11th February 2006 05:20 AM
which is lowest noise bipolar? bane_982 Parts 1 4th March 2005 12:45 PM
Lowest noise levels difi Chip Amps 3 3rd March 2004 11:42 PM
Using Ixys current regulator as current sink. G Solid State 3 16th November 2002 11:23 AM
