hello,
I have a pre-amp unit and an amp unit; What is the best ground connection between the two? Leaving ground passing only trough signal cable shield, or paralleling it with a second dedicated ground cable? Thanks for any useful feedback. |
#2 |
try this:get a screened cable with 2 signal carrying cores,ie 1 shield,2 wires.1 core will be the"signal"and 1 core will be the"ground"and the shield with be connected together with the "ground" at one side only.
#3 |
#4 |
excellent links Gordy.Thanks!
| input connection and ground on ucd 180 | bcrazy | Class D | 2 | 21st March 2007 04:23 PM |
| power supply choke with a connection for AC ground? | jarthel | Tubes / Valves | 4 | 16th March 2007 10:10 PM |
| Beginner Ground Connection Question | TGRANT | Analog Line Level | 8 | 17th September 2006 03:46 AM |
| Acoustat AC ground wire connection | noelm | Planars & Exotics | 7 | 21st June 2005 08:44 PM |
| does connecting mains ground with circuit ground create a ground loop? | jarthel | Everything Else | 0 | 25th June 2003 12:55 PM |
| Page generated in 0.07142 seconds (70.28% PHP - 29.72% MySQL) with 11 queries |
