leach amp parts to-3
Old 22nd February 2007, 10:58 AM   #1
ShanaVar is offline ShanaVar  Austria
Default leach amp parts to-3
any parts substitution for the mj15003/4 for the leach amp that's not to-3 as i got big sinks where its very complicate to mount them and i dont want to buy new ones
thanks
Old 22nd February 2007, 11:32 AM   #2
sixtek is offline sixtek
sixtek's Avatar
I suggest MJL21193 / MJL21194.
Old 22nd February 2007, 03:39 PM   #3
hmm its 7,50€ per piece :/
maybe i should do an other amp, those output transistors are getting really expensive if you need more than 8 of them ...
is there maybe some SS amp with a better quality / money factor?
i know the reference guide, but i cant find all the transistors for krell50(though i'm very interested in doing a krell) , aska only offers kits and the leach amp, well i read good and bad things, but i think dr. leach knows what he does, but the transistors are a little exp., i dont like the aem6000, and i'm not sure what to think about elliot's and jhl. but jhl in original gets exp. too because i think its supposed to go with 6x60k uF. i like mr. pass designs -even did a zen - but only with horns - as they are sadly "source" amps, and thats not what i got/want(horns).
i'm able to spend 150-200 euro, but i'd like to save what i can =]. at least i got the heatsinks (and one 300va 25-0, 25-25 transformer).
thanks for any advice
Old 22nd February 2007, 03:52 PM   #4
200euros will buy you a chassis and some hardware.
You then have to source the amplifier and PSU and heatsinks.
If you can cobble together a home built chassis and source a lot of secondhand/cut price parts you may be able to manage a two channel amp for that budget. But not a Krell Klone.
The Leach will work with 2sa1943/c5200 but being just 150W devices with poor SOAR, 2pair will only do 8ohm from 40Vac and 3pair will manage 4ohm from 35Vac.
regards Andrew T.
Old 22nd February 2007, 04:14 PM   #5
well forgot, i got the chassis, the connectors (phono plugs etc..), the heatsinks (though i think i wrote that), the switches etc. all the peripherics (if there is such a word =] ) and one 300va 25-0, 25-0 transformer (i'm not sure if i can use this one though) - so i'd "only" need the parts - and there must be something for around 150-200€ :/
ps: don't tell papa, but i took those bought for the zen i wanted to make/made =] )
Old 22nd February 2007, 05:17 PM   #6
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
ShanaVar,
do a search for posts by Sonnya.
(you're welcome to send me an email for help with your search for parts or grading my skills in typing your lingo.)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 22nd February 2007, 05:42 PM   #7
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: leach amp parts to-3
thanks
I agree with sixtek.
MJ15024 MJ15025 TO-3 is a bit better than MJ15003 MJ15004
but if you can find them in TO-3
MJL21293 MJL21194 will be a real upgrade!
Lineup Audio Lab power devices
lineup
Old 22nd February 2007, 06:35 PM   #8
found the MJL21193 in to-264 (what is better, as moounting to-3 would mean real work and long cables on my sinks, as i'd have to drill a hole next to transistor and stuff the cable through ), i think i'll calculate the amp and hope i can get trough with my budged =], hope it turns out well, as i am tired and frustrated of looking around, and deciding, and looking, etc...
but im open for other suggestions
PS: just reading page 12 of sannyo, he did good job writing lotsa stuff ^^
regards,
Patrick
leach amp parts to-3Hide this!Advertise here!
High Current Leach/leach super amp bowdown Solid State 41 2nd March 2011 02:15 PM
2 channel leach amp PCB and parts BuzzerBro Swap Meet 10 22nd January 2009 11:32 PM
Elliot 3PA or Leach amp. parts FS NerdMike Swap Meet 1 17th July 2005 06:21 AM
PARTS PARTS PARTS!!! Infocus Powerview 820, triplet, ballast, light, power supply!!! marioinla Swap Meet 1 31st August 2004 04:22 PM
ESP 3A or Leach amp parts for sale NerdMike Swap Meet 2 12th December 2002 03:37 PM
Copyright ©1999-2017 diyAudio
