Old 16th February 2007, 02:19 PM   #1
legarem is offline legarem  Canada
legarem's Avatar
Default Exposure model 8 output transistors
I have an Exposure 8 amplifier with blown output transistors on left chanel.
The output transistors are TO3. The company buffed the numbers on them. I suspect that they are bipolars transistors.
Do someone knows what number they are ?
Old 16th February 2007, 04:13 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
here is a similar topic
at another website
I do not know if they have solved this ...
The complementary transistors are marker SM8540 and SM8554 for the N and P type respectively.
Does anyone know what the modern equivalents of these transistors?
Exposure VIII power amp report
lineup
Old 16th February 2007, 09:23 PM   #3
I have an Exposure XV that im trying to repair. According to Exposure some parts in thier older amps like your 8 and my XV were custom made for them. This is true for the output transistors and larger power supply caps. The parts are rather expensive from Exposure around $15 each for he transistors. Mr Brady from Exposure told me that I could use an Mj15003/4 transistor as a replacement, it will work but he said he would not garuntee the sound quality would be as good as the Exposure part. II got the same answered when i wanted to recapp my amp a year or two ago, they said the capacitors were custom made and cost $35each!! Luckily I found out from a good source that thier custom caps were really BHC Aerovox with an Exposure label and i saved myself about $80.
Old 16th February 2007, 10:18 PM   #4
legarem's Avatar
Thanks for these informations
Where can we find BHC caps in North America ? I thought replacing the ones in my amp with Panasonic TSHA Caps
Old 17th February 2007, 09:18 PM   #5
I got mine direct from BHC as samples. You would have to contact them about local dealers. Most likely any good quality cap will give good results but I went with BHC because thats what the origionals were and I wanted to stay as close to the orgional sound as possible.
spice model for UL output transformer? docali Tubes / Valves 29 4th May 2011 06:42 PM
PSpice model of output transformer oshifis Tubes / Valves 4 8th August 2008 02:02 PM
Exposure output devices? Mark25 Solid State 2 23rd February 2007 11:11 AM
Classe model 10 output transistors willcycle Solid State 0 10th December 2005 04:31 PM
output transformer spice model Paracelsus Tubes / Valves 6 9th September 2005 02:52 PM
Page generated in 0.09153 seconds (70.32% PHP - 29.68% MySQL) with 10 queries
