I have an old amp laying around collecting dust because it has a high pass crossover at around 250HZ (guessing around 12db/octave). My question is simple but Im not sure if its easy to solve. How would I go about locating and removing/altering this crossover for a lower high pass point? Seems like a long shot but maybe you guys can help...
Thanks -Sergio |
#2 |
What is the amp?
#3 |
Three things puzzle me a bit about your description. These are "old", "12db" and "cross over". My first thought was that it may be a realtively cheap (old) Oriental design with a 6db slope rumble filter. They have been known to cut in at a high frequency. But as the previous post said we would need more info'. If thats possible then the changes aren't too difficult to do. My second thought was to ask if it's a car amp?
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse. |
#4 |
No its not a car amp...its actually off a computer system that was sold a few years back. Its not THAT old but yeah...used that term a little loosely there
Basically the system consisted of a sub and four speakers...the frequency response said 250hz-20K for the highs, so Im assuming thats where the filter is...Its a long shot and I would be surprised if you guys had an answer....I wanted to use it for a couple of full range speakers for my computer again...naturally the filter kills the purpose.. Thanks -Sergio |
#5 |
I would open it, and try to follow the singal path till the point it divides into the subwoofer section and the other speakers section.
The filter will probably be at the beginning of the speakers section. |
#6 |
the response was probably due to the incredibly SMALL diameter cones on the speakers...unless the specs specify a crossover..usually manufacturers cut as many corners/cost as possible...
none |
#7 |
This amp is probably designed for low power. Are you sure you want to run it full range with perhaps less efficient speakers?
#8 |
Its only a 3 watt amp, And Ill probably run more efficient speakers, Or I may make it into a boom box
-Sergio |
| ppi epx 205, interesting crossover (to me, at least) | ppia600 | Car Audio | 2 | 25th February 2008 05:50 AM |
| Here's an interesting TL pipe question ??? | Fish Chris | Subwoofers | 16 | 1st February 2007 08:10 PM |
| interesting sub enclosure question? | aaronp1 | Car Audio | 11 | 13th October 2006 05:36 AM |
| An interesting capacitor question | KBK | Parts | 40 | 11th August 2006 01:41 AM |
| Interesting question | rs1026 | Chip Amps | 7 | 24th November 2004 03:21 AM |
| Page generated in 0.13741 seconds (50.19% PHP - 49.81% MySQL) with 10 queries |
