Old 15th February 2007, 05:05 PM   #1
jackinnj's Avatar
Default Crown IC-150A POOGE
The Crown IC-150A Preamplifier is one of those early 1970's devices with beaucoup of room in the chassis -- and it used an LM301 opamp -- the IC-150A has a stepped attenuator, tone, balance and a "panorama" control, abundant use of Siemens silvercaps -- here's the linestage and power supply -- while it is a thing of beauty, it must undergoe the surgeon's knife:
and
Old 15th February 2007, 06:13 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi jackinnj,
Go for it! They didn't sound that good either. Between upgrading the power supply and other active stages, is there anything but the chassis worth keeping?
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 15th February 2007, 06:58 PM   #3
jackinnj's Avatar
the chassis and front panel are very nice construction. the transformer seems to be of the UTC variety -- they have all of the inputs grounded onto the chassis so i purchased some insulated Au-plated variety to fit in there. the attenuator is of very high quality.
Old 15th February 2007, 07:10 PM   #4
anatech's Avatar
Hi jackinnj,
Are you thinking discrete or another op amp unit?
I probably would have gone with Ag or some other finish. Gold doesn't seem to hang around long on most jacks I've seen.
-Chris
Old 15th February 2007, 07:17 PM   #5
FastEddy's Avatar
sure would like to see a picture of the insides ...
Is there room for a torrid xformer? alternate pre-amp boards? possibly an EQ board? are those IC volt regulators in the PS diagram? (Is that a Nixie pilot light? = the unsung hero of high freq. on the AC voltage filters.)
Old 15th February 2007, 07:19 PM   #6
I've repaired more of these over the years that I would admit...but in reality the chassis is probably the only good part of it. I'd use it for a good tube line stage.
Mark
KSA-100 WIKI
Old 15th February 2007, 07:51 PM   #7
anatech's Avatar
Hi FastEddy,
Why? EI's sidestep many torroid problems and there isn't a height issue here.
Hi Mark,
I've done a few as well. I think I'd stick with a solid state unit. Use an old computer hub for a tube project, complete with visible tubes hanging out the top!
-Chris
Old 15th February 2007, 09:42 PM   #8
jackinnj's Avatar
Originally posted by anatech
Hi jackinnj,
-Chris
I am going to use this combination of AD825 + AD826 for the line amp.
I think that the phono board is going to be OK.
The power supply will get a pair of super-regs.
Old 16th February 2007, 12:48 AM   #9
anatech's Avatar
Hi jackinnj,
Ah ha! A composite op amp. Less expensive maybe than BUF04. This should be interesting to see how it plays out. I'm sure it will perform considerably better than the orginal.
Yup. Can't hurt.
-Chris
Old 16th February 2007, 12:57 AM   #10
mikeks is offline mikeks  United Kingdom
Account Disabled
Where are your tone controls?
Schematic for Belles 150A F1 FAN Solid State 0 28th May 2009 03:06 AM
old crown IC-150a preamp otaku Solid State 2 26th June 2004 06:00 PM
pooge-ing wrl Solid State 0 31st December 2003 06:33 AM
Pooge 5.51 pcb audiodoc Solid State 4 25th November 2002 08:55 AM
Page generated in 0.19277 seconds (51.49% PHP - 48.51% MySQL) with 10 queries
