DC Offset Problem with Micromega Amp
Old 14th February 2007, 09:46 AM   #1
delory is offline delory  United Kingdom
Default DC Offset Problem with Micromega Amp
I have just replaced a Micromega Tempo 2 amp (working perfectly) with a Tempo P pre-amp and a couple of Audiolab 8000M monoblocs. When I connected everything up, unfortunately I didn't notice that one of the Audiolabs was switched on, not that I'm sure this was a problem. Anyway, when all was connected I turned on the Micromega and received a loud burst of music through the speakers (approx 1 second) then the pre-amp switched off and started flashing "dco" - meaning DC Offset.
Now if I disconnect the pre-amp from everything else, and just plug the power supply into it, it still shows the same error message.
Reading the Micromega manual, both the Tempo 2 and the Tempo P have this safety setting, but the Tempo 2 still works fine. However it says if the Tempo 2 says "dco" then return it to Micromega, but if the Tempo P shows it, then it is the power amps which are faulty.
Can anyone enlighten me as to what the actual problem is? Is it the pre-amp, or the power amps? If it is the power amps, why is the message still appearing on the pre-amp when it is not connected to anything? Does this mean that something has broken:blown in the pre-amp or will it "reset"? Reading another post on DC Offset, one user said that he measured the DC from his amp, and it peaked when the amp switched on, then after about an hour it disappeared.
Any help appreciated, as sending things off to Micromega is not cheap!!
Old 14th February 2007, 10:06 AM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Without knowing the preamp, the output buffer might be faulty. Check fuses, try to locate and measure the output transistors.
Picture of the inside?
/Hugo
Old 14th February 2007, 10:08 AM   #3
Ok, I'll take a pic and post it here if it will help.
Old 24th December 2007, 06:12 PM   #4
lfournier74 is offline lfournier74  France
I recently repaired my tempo 2.
This amplifier seems to be very sensitive to DC output because it is DC-coupled.
I have written some words about it in french - apologizes ! when it got a second youth... definitely a nice amp.
Here is my webpage (I am not allowed to publish it) :
http://lappweb.in2p3.fr/~fournier
then look for micromega tempo 2.
btw, if you are interested by the phono preamp, I am still experiencing because I could not easily make a PCB. I expect to to it asap...
Cheers
Laurent
Old 1st May 2011, 09:33 PM   #5
mbosko is offline mbosko  Yugoslavia
Hello
I have Micromega Tempo 2 amplifier but digital part is defective
Who can help me with EPROM HEX dump
Eprom is 27C256 Label TEMPO/V1.5
thanks a lot
Old 2nd May 2011, 06:57 AM   #6
Default to mbosko
I don't have my archives here, I have a look asap for the PROM (I think it is a v1.5). BTW, check the short ribbon between the power section and the preamp, the connectors may have been oxyded. I had to replace it since it was almost out of order and I had some grounding issues. Be careful, these connectors are fragile. Also check the auxiliary power supply coming from the transformer and the small connectors around. You should then ensure that the microcontroller (the 40-pin IC on the preamp) has its 5V (between pins 20-GND and 40-+5V).
In the meantime, I check for the EPROM...
Laurent
Old 2nd May 2011, 12:37 PM   #7
@ Laurent
Hi
Thank you very much for support
I am waiting for EPROM file
You can email to mbosko@ptt.rs
Thanks a LOT
Old 6th May 2011, 07:53 AM   #8
Just received letter from "new" Micromega
"Dear Sir,
Thank you for your message and your interest for HD MICROMEGA products.
Actually,the ex-Micromega company has collapsed about three years ago, and isno more existing... "
So, will be a lot of problems for owners of Micromega products
It is not possible to get users manuals for older products , imagine servicing ?
Old 14th May 2011, 04:43 PM   #9
ikap is offline ikap  Serbia
HI,
I have Micromega Tempo 1 Firmware, possiblly, it`s same!
DC Offset Problem with Micromega AmpHide this!Advertise here!
Another Offset problem... rtate Solid State 6 19th March 2008 11:03 AM
Micromega Duo Transport Problem delory Digital Source 0 24th January 2007 11:14 AM
Micromega Stage 3 problem wac38 Digital Source 3 18th January 2007 07:22 PM
A40 offset problem? stickleda Pass Labs 8 1st May 2005 12:56 AM
Is this DC offset problem. rs1026 Chip Amps 4 24th December 2004 12:02 AM
