#7051 |
Try one of these ones.
Rifa will work fine too. regards, Carlos .................................... Gonna try to do it Duda. Thanks. Carlos
Audiophoolery; http://www.youtube.com/watch?v=m7ERMu825m4; Dx Super Etching; http://www.youtube.com/watch?v=WED3Bvmxepk |
#7052 |
I will met Doctor to ask permission to be sitted for long time.
To the ones does not know uncle Charlie, this is to be soldered at the copper side...you see that solder was melted already, preparing the surface to easy accept component terminals... this method is easier, you can inspect the circuit while soldering...you have not the copper tracks in the other side needing transparency, or lamp below to watch lines...here, all copper lines (tracks) are there for you to see. To produce prototype there's no better way...no bad contact as you have in protoboard, no mess of wires...if you try once, i am sure you will never try the other way to prototype, because it is the easiest and most practical way to do.... there are some simple skills needed...have to solder from the left to the right if you are right handed..doing this way, soldering iron tip will not burn component cases. Of course, when ready, adjusted, passed...then you produce the standard board style, with holes, silk screen and whatever you want/need.... this is for prototype. regards, Carlos
Audiophoolery; http://www.youtube.com/watch?v=m7ERMu825m4; Dx Super Etching; http://www.youtube.com/watch?v=WED3Bvmxepk Last edited by destroyer X; 4th June 2012 at 10:15 AM. |
#7053 |
I forgot important connections to the board that makes the circuit to operate dinamically...it was operating statically alike a bias trimpot.... no feedback was beeing readed and no dinamics biasing was actuating.
Because of that, please, wait further testings to assemble you unit. Here you have a video informing what is going wrong...i forgot the X shape white wires you see...jumpers to the board i forgot: Do not assemble Dx Super A for a while - YouTube Next amplifier to be connected and tested together the Dx Super A module will be the Dx Blame ST..and them i will assemble the Dx amplifier to test together the standard unit. regards, Carlos
#7054 |
Carlos!
I finished the building of one Channel of the DX Amp TODAY. Man... What a good amplifier! I used a SRPP preamplifier before the DxAmp and the sound is amazing! My best to you! PS: I did a post on my blog about your amp here: Felipe Navarro Kind regards, Felipe Navarro |
#7055 |
The Dx Blame ST is much better in sonics....more ballanced related bass and treble, better dinamics, smaller distortion...overall superior quality.
I do still love the Dx standard amplifiers...but since you compare you start to perceive it has something less in the high end.....and some lovely excess of bass. regards, Carlos
#7056 |
It is a little bit loosen.... say "out of control"..... deep and loooooonnnng.
I love it because of that bass. A friend have published a video about it... see it here: DIY Dx Amplifier powering my 12inch mtx sub - YouTube regards, Carlos
#7057 |
#7058 |
#7059 |
Are you joking, Carlos ? On this desk, speaker produce not bass, but only good farts....and maybe yours are better at this place...
#7060 |
Ahahahahahah!
.... that video does not show a very good bass because the camera is unable to record deep low frequencies... so...it sounds like a fart as you said.... really sounds this way..but i know this is due to the camera's audio recording...for sure it is:http://www.youtube.com/watch?v=k-he3...eature=related Blame series are more precise...no doubts about that.... these Dx Amplifier (standard) pcboards are pirate copies from China...i do not know how they sound in the reality as i have not tested...but it looks the camera have messed with the bass....this music also sounds like a fart too. The more modern ones...the Blame series...are so good that you can smell A good plastic surgeon can tune your expanded exaust Epupa, then the noise will be better than this one you use to listen. regards, Carlos
Audiophoolery; http://www.youtube.com/watch?v=m7ERMu825m4; Dx Super Etching; http://www.youtube.com/watch?v=WED3Bvmxepk Last edited by destroyer X; 1st September 2012 at 06:40 PM. |
