Destroyer x Amplifier...Dx amp...my amplifier - Page 699 - diyAudio
Old 9th December 2011, 10:26 PM   #6981
Default Finish DX Amplifier with some humming...
i figure out 2u2f i used 2.2uf/50v electrolytic capacitor but how can i minimized the humming coming out from the speaker going to DX Amplifer...any idea
Old 9th December 2011, 11:30 PM   #6982
norazmi is offline norazmi  Malaysia
it should not have any huming at output, please can u determine with multimeter voltage in DC at output stage without any input sound (at idle). Looks like u have DC voltage at output...
Old 9th December 2011, 11:34 PM   #6983
can u post some picture of ur dx-amp?
Old 10th December 2011, 08:18 AM   #6984
destroyer X's Avatar
Default Use good shielded cable in the input
This can be your problem... this happened before...bad input audio cable.
Also be shure the coaxial audio cable shield is really connected to the ground...if inverted you gonna have hum.
Check supply filtering and increase distance (clearance) in between power supply and audio amplifier pcboard.
Post pictures....high resolution ones...from cell phones are not good to allow us to help you.
regards,
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg, Sample Dx Classic https://www.youtube.com/watch?v=fVvFrwl92RU
Old 10th December 2011, 02:33 PM   #6985
i check the output side with multimeter and idle mode i measure a 0.24dc volts and even i connected the ground one but there is still a humming...
Old 10th December 2011, 02:35 PM   #6986
hi to everyone please help me to properly connecting this amp came from tamircihasan amplifier i cannot properly run it... hoping for your help....thanks in advance...
Old 11th December 2011, 10:04 AM   #6987
Default Print a copy from your schematic and check each part
tracing red lines, with a pen, into the schematic printed in the sheet of paper...this way you gonna be sure every part was checked, also that all copper track connections are there...you will see shorts (check with ohmeter) and missed tracks, bad solder joints, missing parts and so on.
Could not find?
Then check each part value measuring with your ohmeter...check each transistor and each condenser and capacitor polarity installed into the pcboard....lift at least one side of a resistor to measure it disconnected from the pcboard.
Could not find?
Check transistors, remove ALL them from the pcboard and check each one of them, if NPN or PNP...if numbers are correct and if they are conducting correctly.
Could not find?
Replace suspect transistor by other ones
Could not find?
Go to the church as ask the priest some blessings man.... or try some magic, wizard or gurú to discharge your body from bad energies
ahahahahaha!
regards,
Carlos
Old 11th December 2011, 12:25 PM   #6988
hahaha i really laugh to your message destroyer x hahaha... i will do your step by step technics
by the way i only use 15 0 15 with only bridge diode and not using electrolitic caps to filter an AC line....is this one factor of getting humming....
Old 11th December 2011, 01:43 PM   #6989
can i ask about this IC VBIAS what is the part number...and what is the purpose of this vbias...
Old 11th December 2011, 02:44 PM   #6990
you can use any NPN transistor, picture u post here is BD139.
Copyright ©1999-2017 diyAudio
