Old 29th November 2011, 05:55 AM   #6951
destroyer X's Avatar
Default I am glad you found the problem
Enjoy your amplifier...this is all i want.
regards,
Carlos
Old 29th November 2011, 07:51 PM   #6952
norazmi is offline norazmi  Malaysia
triple times build this amp, no error all 3 of them, happy with it, play hard also nothing burn :P
Old 29th November 2011, 09:14 PM   #6953
Default I am glad to know that Norazmi
I do think this amplifier is very reliable.
Thank you,
regards,
Carlos
Old 2nd December 2011, 10:29 AM   #6954
Can I replace the Bd139 by H1061 ? Bd139 is not common in my country.
Old 2nd December 2011, 11:11 AM   #6955
AndrewT is online now AndrewT  Scotland
What is an H1061?
Old 2nd December 2011, 02:16 PM   #6956
Originally Posted by AndrewT View Post
What is an H1061?
It 's a NPN tranzito ,This is data sheet of its. H1061 pdf, H1061 description, H1061 datasheets, H1061 view ::: ALLDATASHEET :::
Old 2nd December 2011, 02:34 PM   #6957
Default Yes, you can substitute by H1061
It is cousin of the 2SC1061..... a little bit more strong but seems that belong to the same family.... you can also use TIP41C and TIP42C to all amplifier positions...i did that at home...even the differential have used TIP42C.
Result was not that good because TIP41C/42C are low speed transistors...but worked fine too.... i little bit slow i think, treble use to be better when using BD139/140.... these ones are the best sounding devices (if we can say transistor sounds), as work very well with colector voltages up to 40 volts.
Depending your substitutions you may have different adjustment to the bias trimpot, also the off set trimpot...but this will be the worst case scenario.
Be happy, enjoy, publish pictures..if you did, then publish more.
The more modern versions are more efficient as result of better construction techniques, higher speed and higher dissipation
regards,
Carlos
Old 2nd December 2011, 02:36 PM   #6958
Originally Posted by astankov View Post
BD139 and BD140 are complementary pair this means that they have exactly the same parameters but different polarity one is NPN and the other is PNP.
In your case there is no complement according to the datasheet so it is not suitable. You can try MJE 340/350 , 2SC4793/2SA1837 , MJE 15030/15031 , TIP41/42 and so many others.
But in DX amplifer schematic, only use BD 139, not use BD 140
Old 2nd December 2011, 02:44 PM   #6959
here 's result of my test voltage ,I replaced BD139 by H1061 in the schematic original , I remove all tranzito and test, but all of them is good.
Old 2nd December 2011, 02:53 PM   #6960
astankov's Avatar
Sorry , my fault. Thats why I deleted my post.
Copyright ©1999-2013 diyAudio
