#6941 |
Bias adjusting, off set adjusting, amplifier playing...seems you succeed... congratulations.
regards, Carlos
Sons visiting uncle charlie; http://www.youtube.com/watch?feature...&v=5T76qsvZrdw; http://www.youtube.com/watch?v=Hb_wolQGU5Y |
#6942 |
now i test and adjust the offset on output terminal and it reads. 1.0 and my multimeter was set to 200mV. i think this is ok. any opinions?
i have a hard time in tweaking the bias (VR3), the values in my Meter continue to increase. i leave it about 600mV and now it reads 636mV. are there any problem or is this normal? the amp is almost 30mins powered on. |
#6943 |
Thank you so much Sir Carlos. :]
#6944 |
its working but it hums. and there is speaker pop when turning on and off. maybe i will try DX MKII or MKIII. good night folks. hope i will fix this amp next week.
#6945 |
or because you are using MP3/4 player in the input.
There's no registered complains about hum in this amplifier...you are the first to report this. Power on thump is normal in this amplifier. Current drift from cold to normal operation and hot operation is normal too. Differences of stand by current when you measure the positive rail compared to the negative rail is also normal...this amplifier sucks more current in the positive rail because of zener current you have in the positive rail regards, Carlos
Sons visiting uncle charlie; http://www.youtube.com/watch?feature...&v=5T76qsvZrdw; http://www.youtube.com/watch?v=Hb_wolQGU5Y Last edited by destroyer X; 25th November 2011 at 06:15 PM. |
#6946 |
#6947 |
2SC5200 and 2SA1943 are the next generation.... they are cousins... they are almost the same...small differences in power dissipation and other details.
No problems...will work fine and great with them. regards, Carlos
#6948 |
#6949 |
Congratulations..... it is looking good...you have made a silk screen..... that's nice.
regards, Carlos
#6950 |
its my bad that's why the amp produce hum. its because the wire i used in the input creates noise. so i wired up coaxial wire and it sound super silent. without noise and hiss. i'm very happy with this amp. i just want to try the dx mkIII-hx soon. God bless you carlos.
