Destroyer x Amplifier...Dx amp...my amplifier - Page 653 - diyAudio
Old 16th November 2009, 08:28 PM   #6521
destroyer X's Avatar
Default have received a big package containing gifts from dear friends
Some parts were waiting since last year.
Sakis sent me electrolitic condensers and several usefull parts.
Taj sent me also electrolitics and a lot of other parts
Duda sent me the function Generator and those pens you can see...all parts are very usefull.
Thank you very much, dear friends....uncle Charlie is feeling good....feeling great as i see i have some friends that usually remember me sending me electronic parts.
regards,
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg, Sample Dx Classic https://www.youtube.com/watch?v=fVvFrwl92RU
Old 16th November 2009, 08:53 PM   #6522
Default More pictures about the package received.
Sakis and Taj have sent parts to Dudainc, as he has a Company in the United States.
Duda use to travel to Brasil, at least once a year to visit her mother..then he use to bring those parts and mail them to me using Brazilian internal mailing system...so...avoiding customs troubles.
regards,
Carlos
Old 17th November 2009, 04:17 AM   #6523
Masterinvi's Avatar
uncle carlos, i set again the offset bias in greg's site tutorial(thanks to him), i install the vbe multiplier, i replace the input capcitor electrolitic 10 uf to 1 uf/50v, and guess what? speaker is now smiling when powering the amp, it will move a very very little that cant notice it unless you touch it. and the music? superb!!! more sonic more clear.
I install 10 1000/50v caps in power supply as filter 5 each supply rail in addtion to 1 4700/50v caps in each rail. i have lots of caps in junk TV board so i add them to the amp.
thanks again uncle carlos.
Old 17th November 2009, 05:22 AM   #6524
Default Now i am feeling better, was strange that power on noises
as i have worked a lot to reduce it almost to zero...was made tweaking and changing circuits into the input... the zener voltage regulator and the low capacitor values gave me a noiseless power on...i had not the same result while using CCS, also i had not the same nice sonics using CCS.
You can see here, the noiseless power on in this video i made to prove folks it is noiseless....happened with some folks that "effect" you had.... you know, an effect and fast grow up to be a defect... reason why i have made the video to prove it is noiseless.
YouTube - Dx Amplifiers, noiseless during power on and off
thank you by the informations... really, the amplifier sounds perfect using 1 to 2uf into the input, in special when the capacitor has not polarity.
regards,
Carlos
Old 17th November 2009, 11:26 AM   #6525
Masterinvi's Avatar
thanks again uncle carlos specially the video.
when i power up the amp i didnt hear any blag!! or boom!! or whatever noise. i just see the speaker that will move very very very little. almost nothing.
i have 1 sansui amplifier and i compare it in powering up. sansui will not move even a little, i open the amp and i've seen 1 relay for output, i notice it will click about 1 or 2 seconds after powering the amp. so i jumper the two contacts of that relay and power that amp, i hear a blag!! from speaker, so thats the trick of that amp. they delay so that noise will not be heard.
I believe i've not perfectly constructed this dxamp. WHo cares? This amp sounds like a charm the most i like is that i can play it all day and night long without worry. i let it play again at 8 in the morning until about 8 in the evening, i just let her play and leave her to do my works. when i visit her again the transistors are normal, i touch it its not that hot just normal, you can touch it as long as you like. she doesnt have any blower or fan for cooling. Thats how reliable and stable this amp of yours. thank you again.
i have one quiestion, i try this amp to drive my 300 watts 15 inches speaker, it seems that she likes to drive 8 to 12 inches speaker because in 15 inches seems like there is distortion or change in sonic if i turn the volume to higher. But if 12 inches 200 watts with same volume level no distortion i hear.
Any explaination regarding speaker?
Old 17th November 2009, 04:32 PM   #6526
Default Those big speakers, usually, needs a lot of power.
The amplifier can deliver 50 watts rms...and average is half of that....so.... not good to drive huge speakers.
That's the bad thing about the stuff...to drive big speakers we need huge power, and then the speaker moves the same as 10 watt speaker driven by a 10 watt amplifier...audio molecules compression are the same with both conditions..sound pressure too.
So...the big speakers force you to have big amplifiers...it is a bad trick... in the reality a trap.....people think that will have more sound.... they are wrong..they just spend more money for that stuff.
Post a picture from you amplifier..this is good to my files.... i am preparing a video showing pictures of all Dx builders... a very long video were i would remember all folks..but will not be ready soon, there are a lot of pages into our forum to search from original pictures posted..all them old style...100k images... a pity that... send me a picture if you do not know how to post it.
Do not worry if pretty or not.... my stuff use to be ugly but sounds nice!.... also pictures from you is interesting..also the dog, the house, the car, the bicicle, the tree, the cat, the neighboor, the landscape, your wife, your childrens, your mum, your boss and the dog's pooh...everything is great to me...that flag...i never know the country...i cannot recognize all country flags.
There are a lot of awfull speakers..sounding terrible.... audio equipment depends from the speaker alike radio transmissions depends from the aerial (antenna).... the amplifier can be good or bad, depending the speaker selected.
carlos.eugenio1951@yahoo.com
regards,
Carlos
Old 17th November 2009, 07:06 PM   #6527
Default Gifts received from Dudainc.... these parts came from Dudainc, Sakis and Taj
All them good forum friends,
thank you very much folks!
regards,
Carlos
YouTube - Gifts from Dudainc, Sakis and Taj
Old 17th November 2009, 08:04 PM   #6528
Default Rudi use to listen together friends to evaluate amplifiers
And you all know i love that stuff too.
Will post several pictures, and maybe one each post, as the 1 Megabytes limit is to the post..so, i cannot post three pictures having 1 Megabyte each one of them...i am forced to post three pictures having 300K.... at least i am having problems to attach those pictures..the forum software is giving me a hard time related to attach things.
Sometimes does not finish...we go waiting and do not finish the attachment operation.
....Well..too much delay.... so i will upload to image shack and will post the link.
regards,
Carlos
Old 17th November 2009, 08:09 PM   #6529
Default Rudi Rozek amplifier...a Dx Amplifier...nice construction he made
regards,
Carlos
Old 17th November 2009, 08:13 PM   #6530
Default These meetings, to evaluate audio together, they call
"stammtish"... very complicated, even to pronunciate.
hhehehehehe.
Carl
Copyright 1999-2017 diyAudio
