Destroyer x Amplifier...Dx amp...my amplifier - Page 617 - diyAudio
Old 26th May 2009, 09:32 PM   #6161
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Next I found 8x BD139-10
Original Motorola goldleg, about 30years old
But used, so I need to find whether they are ok too
Also some unused BC547B, with goldprint and looks like Motorole or AA(?), also equally old
Also a couple of BC560B, goldleg Motorola, but used and old
Are these gems, or should be thrown away
I think I rember someone mention That those old Motorola to be really special
Lots of resistors I have to measure
Am I getting into trouble
Just be honest Carlos, should I quit these parts
sometimes we know very little, and sometimes we know too much
Old 26th May 2009, 09:49 PM   #6162
I also have this funny thing on my meter
Obviously fore testing something, NPN-PNP
But have no clew how it works
Is it of any use
Taj
Sounds good with your dad building violins
I have to be honest and say that have made one many years ago
And the one, not finished, that I showed to Carlos, I have been working on that for about 15years, or more
But it is an important part of me, and will always be
Im working on my house
Havent had a proper bathroom fore 5years, but close to get it done
After that I hope to get a dedicated room fore making some more violins, I wish
Actually I have all the needed wood fore a couple more
Nice old stored wood by now
Should manage to get them done before I get too old
Old 26th May 2009, 09:52 PM   #6163
dudaindc's Avatar
Default DX LOGOS
Originally posted by taj
Elephant logo huh? Okay, but I still think it's weird.
..Todd
That is too funny...
I still like the ones you posted first.
Yes indeed... personal taste is not a matter of discussion.
"All measurements are wrong! Thus, measurement is the art of handling errors."
Old 26th May 2009, 10:22 PM   #6164
destroyer X's Avatar
Default Oh...nice parts...those 2SC2922 and complementary are the best ones you can find
Also the other ones are nice parts.
Do not trow them out...or..trow them into my trash box.
heheheh.
regards,
Carlos
Gaetan, from Canada, also produce violins.
Sorry, Brazil only to be sold... top secret ultimate schematic, not to share...encapsulated VAS:
https://www.youtube.com/watch?v=PHnAky2fV1w
Old 26th May 2009, 11:36 PM   #6165
taj is offline taj  Canada
taj's Avatar
But have no clew how it works.
Is it of any use?
Yes, it's helpful to tell you approximately what the current gain (hFE) of the small transistors is at some current level, so you can approximately match them. There should be a hFE position on your meter's main function switch.
Best use is for the input pair transistors (aka: the differential amplifier or Long Tail Pair). Those two transistors do their job best if they are matched.
The meter is not the best way to match them, but it's better than nothing. And assembling a better matching circuit is a pain the butt.
Insert a transistor ( using correct E, C and B pins - DX amp uses PNP (polarity) for the input pair), and the meter will tell you the hFE reading. Pick two transistors that have the closest reading.
Note: the heat from your fingers will REALLY screw up the readings. so try to use needle-nose pliers or tweezers to insert the transistors. If you must touch them, wait a long time for the reading to "cool down".
That process is really educational to demonstrate how sensitive transistors are to small temperature changes.
..Todd
Old 27th May 2009, 12:48 AM   #6166
Default Re: Oh...nice parts...those 2SC2922 and complementary are the best ones you can find
heheheh.
I may just do that
Its a pain to measure all those hundreds of non assorted resistors, and only find a few right ones
Maybe I just give in and order the needed parts
Thanks Taj
I will try that
I also have a file saved somewhere with instructions fore matching
Man, my eyes hurt and head is spinning, time to rest
Old 27th May 2009, 07:38 PM   #6167
Hi Carlos
Finally my newly bought laser printer, HewlettPackard P5, old blackandwhite, got into use that makes sense
Actually I bought it mostly to make print of schematics, reading stuff etc
1. Any idea why the prints of boards ends up wrong size?
2. Also, is it common to mirror image bottom layer?
My Sankens seems to be shorted on all legs
3. If I buy new, is it ok to choose Sanken 2SC2922/2SA1216?
4. Could I use other drivers than TIP41/42, say TIP31C/32C?
5. Or maybe MJE340/350?
Old 27th May 2009, 08:11 PM   #6168
Default Yes, you can use those drivers.
no problems.
regards,
Carlos
Old 27th May 2009, 08:19 PM   #6169
Default The image you have posted show the copper lines
seen througth a transparent board.... alike a transparent glass board.... position is fine...indicated base colector and emitter.
regards,
Carlos
Old 27th May 2009, 09:10 PM   #6170
Thanks Carlos
The reason I show picture of bottom layer was to show how much size is off, when I print it
Says that board should be 98mm long, but my print is 160mm
How can I fix this
Or I will need to draw the hole layout by hand
Prices are high on components
Will try look at digikey
Got nice F5 boards today, but thats a project fore colder days, only collecting components now, some fore DX also, and other projects
Copyright 1999-2017 diyAudio
