Old 30th April 2009, 05:05 PM   #6051
norazmi is offline norazmi  Malaysia
Thanks Dx,
Its 2N5401, i`ll check VBE multiplier again
Azmi.
Old 30th April 2009, 05:08 PM   #6052
hmmm.. Yes DX, there is no voltage from point A to C, it should be read 2.7V right refer on your website, so the BD139 problem? or maybe both tips trans?
Azmi.
Old 30th April 2009, 05:08 PM   #6053
destroyer X's Avatar
Default I have found the mistake
This one.... correct value here is 4K7..... yellow, violet and red
regards,
Carlos
Old 30th April 2009, 05:19 PM   #6054
Default Check this under the board.
regards,
Carlos
Old 30th April 2009, 05:37 PM   #6055
Changed to 4.7K, and get 2.7V at VBE but still got high voltage at output trans leg 1&3 both npn and pnp.
For your information DX, the tip41c heat up (growing) and tip42 is cold.
I`ll check the board with your suggestion.
Azmi.
Old 30th April 2009, 05:48 PM   #6056
Default Bias Check..
Hi Dx,
Here is the bias preview,
http://60.48.69.81:90/~azmi/bias.JPG
Azmi.
Old 30th April 2009, 05:56 PM   #6057
Default Is this a resistance?... are you sure..have measured?
Check this please.
regards,
Carlos
Old 30th April 2009, 06:00 PM   #6058
Default I would be happy to see the bias circuit by the copper side
or wire side, to check.
regards,
Carlos
Old 30th April 2009, 06:09 PM   #6059
Default A good idea is to clean your board..photo not clear
too much brigh under the board... resine...clean with alcohol or Kerozene (aviation fuel)...or other petrol solvent you may have at home.
Even thinner can be used..but carefull with the other side..parts may melt.
ahahahah!
Is this a short?
Carlos
Old 30th April 2009, 06:13 PM   #6060
Default Only you can check all that stuff
Install your output transistor and protective resistances (alike everybody does)
And them tell me what is going on.
Image not clear...only you will be able to see thougth all this solder resine covering the board.
regards,
Carlos
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
