Destroyer x Amplifier...Dx amp...my amplifier - Page 565 - diyAudio
Old 28th October 2008, 04:39 AM   #5641
Greg Erskine's Avatar
Originally posted by Forever13
Hi Andrew - I've drawn a layout to show what I'd had planned before posting earlier (and no doubt causing alarm!). I've tried to read up on this, and it was only seeing that post on another forum that got me thinking about the centre taps. Isn't this layout right? (earth being a bare metal connection to the chassis that's also shared by the PSU ground, amp power & signal grounds and ground for the speaker output?)
I assume you mean the other way round, Brown live and Blue neutral? (sorry, couldn't help that one)
Thanks again for your help and patience on this.
Hi Carlos - I'll certainly find someone local to help me out before frying myself, the cat, the house, next door...
Hi Forever13,
I can't follow your schematic or follow your wording 100% but the schematic looks very wrong and dangerous to me, please delete it.
There is NO connection between the primaries and earth.
regards
Greg Erskine
Old 28th October 2008, 07:34 AM   #5642
Hi Forever,
hold off connecting the secondaries.
bring all four secondary wires to a 4bay terminal strip.
Just do the mains side first and power it up through the tester.
When you report back on powering the transformer only, we can safely lead you through the next stage.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 28th October 2008, 07:50 AM   #5643
Thanks guys - glad I asked rather than doddering on myself, could have been nasty.
Carlos - thanks ever so much, I'll be in touch later today.
Greg - will do - it's now gone, and thanks for the no-nonsense warning. I'll get advice from someone locally on this now.
Andrew - as above, I'll hold off doing anything else with the power until I get some first-hand assistance.
Old 28th October 2008, 07:59 AM   #5644
destroyer X's Avatar
Default No, não, niet, nichst, nada, non.... negative to put primary connected to ground
this is only for secondary...be carefull with primary voltages..insulated them and avoid to touch.... it may kill you!
regards,
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg, Sample Dx Classic https://www.youtube.com/watch?v=fVvFrwl92RU
Old 28th October 2008, 08:18 AM   #5645
Mooly's Avatar
Default What are you like ?
And don't stick your feet in a bucket of water as Carlos does
Old 28th October 2008, 09:06 AM   #5646
Default Yes Mooly, this sketch resulted awfull
Well... at least i have tried to help.
I do not know how to produce coils shape into paint program.
ahahahah!
regards,
Carlos
Old 31st October 2008, 10:01 PM   #5647
Hi
What is wattage of R23 and does coil made in one or two layer.
Duka
Old 1st November 2008, 01:50 AM   #5648
Default What coil?
Are you talking about Dx Standard supply, or HRII?
Also R23 from what amplifier?...
Dx Standard
HRII
Supply
DHR Turbo
Precision 1
regards,
Carlos
Old 1st November 2008, 01:57 AM   #5649
Default Please, try to be more clear into your question
there are many options about
regards,
Carlos
Old 1st November 2008, 01:58 AM   #5650
Default We have many coils, into supplies and into several models
Are you talking about Dx Standard... this thread is about Dx Standard and it does not use any coil into the output..only into the supply.
regards,
Carlos
Copyright ©1999-2017 diyAudio
