Old 7th December 2007, 10:03 AM   #4501
destroyer X's Avatar
Default Corporation camera already into the mail system
This one will substitute the Canon while under corrective maintenance (repairs).
regards,
Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine.
Old 7th December 2007, 01:39 PM   #4502
Default My dearest, lovely, very good friend from Australia, dear Rabbitz
have already started, near to finish, the High Resolution II
I will post some images.
Dx amplifier is an amplifier of heroic people.... heroes use to be interested ... do not know the reason the unit atract those special folks.
Rabbitz had problems into his fingers...some nerves...electrical problem into the fingers.... to move is a little bit difficult... sensor are not giving him too much feedback.... even this way the guy have constructed.
I have to thank you very much because your effort dear Rabbitz..also by the pictures you sent.
regards,
Carlos
Old 7th December 2007, 01:41 PM   #4503
Those Aussies..... always lovely people.... this is very interesting how they can be kind with us.
regards,
Carlos
Old 7th December 2007, 01:45 PM   #4504
Default You do not know Rabbitz as i know him
I have enormous respect by him.... i would like to be possible to travel to Australia, to have a coffee with Rabbitz, also with Hugh Dean, Thorton, Greg Erskine, Alex Kethel, Anthony Holton, harry3, billabong and many others that i will not write here because the list will be too much long.
You, dear Aussie fellow, consider yourself included into the list..you are all excelent folks.
I would be happy to have a beer with those folks.... really i would be happy.... we never know folks.... i have visited and lived in Japan...why not in Australia?
regards,
Carlos
Old 7th December 2007, 01:50 PM   #4505
Default Another image..... Rabbitz is an excelent Speaker constructor
He has expertise into those things.... he is an living Encyclopedia about that.
He shoud write a book and fast...about that.
regards,
Carlos
Old 7th December 2007, 01:55 PM   #4506
Default A real man this one... dear Rabbitz.... he use to put his hands to work into the wood
he use the hardware.. he is not lemmon fruit simulator designer... he use to cut his hands, a real Do it Yourself man.... macho...male!.... those guys that decide to construct a swiming pool and put his arms and hands on work and produce an excelent job.
His speakers, really constructed by hand, are excelent and beautifully finished.... art work.
The knowledge about those things are enormous... a gift to us if he decide to write a book with images about that.
regards,
Carlos
Old 7th December 2007, 01:57 PM   #4507
Default You can evaluate a man by the friends he made into his life
Evaluating by the image...you see his choice...the best possible friend we can have.
regards,
Carlos
Old 7th December 2007, 02:48 PM   #4508
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Default My new friend
After the old girl passed away a few years ago, I have a new special friend.
Old 7th December 2007, 02:57 PM   #4509
Default The old lady was three times more clever and sensitive
Well.... this is my imagination only.
This one has a sad expression.... was he sick when the picture was made?
regards,
Carlos
Old 8th December 2007, 09:43 AM   #4510
Default A Quasi....PNP output, high power unit, for sub woofer purposes
made special for Dudainc, that had bougth a lot of good PNP Sankens at E bay.
The the output transistor quantity may depend from the speaker impedance choice.... around 6 each rail to 4 ohms and 75 volts.
Power will go around 450 watts RMS over 4 ohms...undistorted, unclipped power....continuous power.
More than half of that will be the 8 ohms power.... and 3 output transistors to each rail may work fine.
Transistor selection must be carefull...because the supply voltage is very high.... 2SC4793 and complementary may fit to drivers, to VAS and also can be used as VBE multiplier...the BD139 will work into the VBE multiplier too...voltage there is very small.
The input choice also will need some care.... 2N5551 and 2N5401 may work fine...but will be better to select bigger voltage units.... those ones are very near the rail to rail voltage...their limit is 150 volts...so....may be not perfect....we gonna have half rail there..but even this way not really good and safe...also more linear if you choice bigger voltage units...alike 200 volts from colector to emitter as maximum allowable voltage.
This is an untested amplifier.... for sub woofer purposes.... output is loaded by the zobel..... also the feedback cuts frequency not so high.... the input capacitor can be very increased..the RF filter can be increased too.
Untested...but will work for sure..... made for Dudainc...and other folks that have a lot of PNP somewhere into the junk box.
regards,
Carlos
Page generated in 0.16764 seconds (69.48% PHP - 30.52% MySQL) with 11 queries
