Destroyer x Amplifier...Dx amp...my amplifier - Page 299 - diyAudio
Old 21st August 2007, 08:10 PM   #2981
Nordic is offline Nordic  South Africa
Nordic's Avatar
Firstly, let me say you are improveing, something you need to keep an eye over is space between traces, and especialy close to solder spots... look at that thick line running down to the groundstar underneath the resistors for instance...
Just hide the components and values every now and again so you can see only the traces...
I played around for a few minutes, just seperateing some ground traces etc... and accommodateing for real capacitor sizes... (from the catalog I use to order parts)
Well done !
Old 21st August 2007, 08:25 PM   #2982
destroyer X's Avatar
Default Yes.... lines that goes in parallel are the same as capacitor plates
alike those variable capacitors.... plates very near one each other... copper lines, having not 1 mm (or more), depending the length, can turn small capacitors.... depending where they are...this can create some problems.
Good to create distance, even if you need to reduce the copper track dimensions.
Big tracks, in dimensions, only to the output, where you have enormous currents.... also a good idea to ground frame, and now to reduce resistance, to avoid ground patches into the same line..
Good idea..... not only good.... a very good idea Nordic.
I think, you cooperating, Klaas, Nordic, Ecat and Ostry, will result an excelent job.
Board is already great into my perception..... the evolutions you will make will be alike profit to me, as the one made is already very good.
regards,
Carlos
I am trying to find my blackgate... i wanna try this capacitor Graham told.... i will try an electrolitic condenser... that one arrive here because of Hugh Dean or because of Greg Erskine.... was a gift that came together a mail...nice gift...for sure.
This is the text Graham had published... and because of it i am searching that one...i had two, free to use, but one broke the lead.. a pitty.
"Years ago I used a double trace scope to watch both input and output. I would superimpose the traces at say 20Hz, and then watch them separate as the value of input capacitance was reduced from 100uF.
Divergence (phase shift) was noted once the value fell below 47uF. However this would not be audible unless a very large bass LS driver was being used with good sine response below audibility in the region where drums and bowed basses/cellos could be felt !"
regards,
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg, Sample Dx Classic https://www.youtube.com/watch?v=fVvFrwl92RU
Old 21st August 2007, 08:38 PM   #2983
Nordic's Avatar
Carlos, once on a course we did this test which went along the lines of... your plane crashed in the desert... you can salvage 10 items... put them in order of importance... and then it gave you the items... things like a piece of canvas a compass etc....
We worked in small groups and had to give our own answers as well as a group answer....
Then they produced the answers... which are based on reality...
Turns out the group answer throughout the entire class averaged closer to the correct one than even the smartest individual's there...
Us beginners have so much to learn from each other - to give the masters some rest, but also like anyone who recently learned something, are also keen to share...
I love how this is becomming a true opensource project.
Osty if pretty component placeing counted for points, you would have won mate!
Old 21st August 2007, 08:42 PM   #2984
Default This nice guy is Claudio, our friend from Italy
From Firenze, city of Arts.... world monument... precious town.
Called Florence too.
This thread is special because people here is not faceless.
His thread name if Evilsmelling.
regards,
Carlos
Old 21st August 2007, 08:47 PM   #2985
Default Lock your girls inside home fellows, this one is very handsome
our artist, expert into speaker design and production (enclosures)
An Aussie.... dear Rabbitz,
a very nice guy.
this thread is filled with humans...we have a lot, they also have family, dogs, friends and life...not only letters typed here and electronics ideas.
regards,
Carlos
Greg Erskine is another handsome aussie.
He looks the same as John Lennon... the beatle.
But this one is reserved and do not want images published.
Well.... exception.... a faceless friend..ahahahaha
regards,
Carlos
Old 21st August 2007, 08:54 PM   #2986
Default Gaetan..... in our forum Gaetan 730 is another artist
With enormous connection to nature and to arts, music, and seems he may sing too...has interesting voice.
He leaves into Canadá.... the french part, distant from the town... together small animals and birds into his wonderfull home...inserted into the forest, surrounded by native forest, not garden.... have lakes around and nice landscape surrounding.
This one, a romantic, also dreamer, audio and music lover, friendly Canadien.
Je vous salute!
à bientôt
Carlos
Faceless people should contribute to our crew data base.
Sending images that can be published, informing family name and
some personal informs.
This will be for the future, will be the historical data from the Corporation (we do not pay to dream folks!...we are free to do that!)
regards,
Carlos
Old 21st August 2007, 09:01 PM   #2987
Default I am loving this "crew movement" too.
Lovely to see friends cooperating and living into perfect harmony.
Cooperation, not competition is what produces good friends... and also the best results.
regards,
Carlos
Old 21st August 2007, 09:03 PM   #2988
Nordic's Avatar
Ahhh Carlos, stokeing the good ol' fire again
Attached is Traces alone in PDF format.... ERC test was done, 0 errors, 0 warnings.
File had to be zipped to fit site's 100k limit.
Old 21st August 2007, 09:18 PM   #2989
Default I am not good in English language Nordic.
Your first sentence, for instance, has absolutelly no meaning to me.
Please my dear "faceless" nephew...ahahahahha.
Use those words you should use with children...those very young that are learning to speak.... that simple english.... forum International.... a lot of guys do not understand those strange expressions you use.
Ora bolótas!
I do not use dirty words into the forum...Ora bolótas is a local expression, very soft and educated, that means.... "have to be patient"...or means.."there he comes once more with those things!"
Maybe the same as you were trying to say.... he is trying once to obtain my picture..ahahahaha
I could not have the image from Halojoy....this one seems that had not a face..ahahahhaha...he may be a computer.
regards,
Carlos
Old 21st August 2007, 09:24 PM   #2990
Default Re: Gaetan..... in our forum Gaetan 730 is another artist
Je vous salute!
à bientôt
Carlos
Hello Carlos
I also done somes years of violin making, making a good sounding violin is much harder that making a nice looking violin, and you can learn some by acoustic and physic siences but violin making are still an art using ear and intuition.
I'm in the north, in the Laurentides in Quebec, nice place surround by big forest but cold in winter lower was arround -40 c
Gaetan
Copyright ©1999-2017 diyAudio
