Destroyer x Amplifier...Dx amp...my amplifier
Closed Thread
Old 14th October 2012, 08:26 PM   #7111
vargasmongo3435 is offline vargasmongo3435  Puerto Rico
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Not sure what area it is, but check this out
Old 14th October 2012, 08:32 PM   #7112
alex mm is offline alex mm  Romania
alex mm's Avatar
....... have omited two connection,first from positiv fuse to colector OT, and second from negativ fuse to colector OT will not work ........ see picture
Alex.
Old 14th October 2012, 09:08 PM   #7113
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Thank you Alex... sadly this amplifier was not approved
But this remote output, we can use with several amplifiers, will be alway usefull.
Also thank you by your kindness Juan.
I am playing with that non approved prototype.... using filters and playing with it...soon i will upload a video...a bad quality video but shows the unit working.
http://www.youtube.com/watch?v=TqJWYTNA6KM
regards,
Carlos
Old 15th October 2012, 02:36 AM   #7114
Don't mind the not connected fuses the prototype was not approved dear Alex that is why I is not completed, and I just want it to show where did I stop the layout.
vargasmongo3435
Old 15th October 2012, 07:10 AM   #7115
Default Juan. here you have the circuit i am using to "play with bass"
That is the subject of this small movie here:
Playing with bass - YouTube
If you want to make it, or to produce a layout...then i am posting the schematic.
regards,
Carlos
Old 15th October 2012, 07:18 AM   #7116
Default Herman is having fun with uncle charlie.... he sent me this picture
Crab is an animal that walks backwards...this means he do not advance to the future..he return to the past...and Dx amplifier is past...old amplifier already made.
Hehehehehe...he is right.... does not make sense to go "forward to the past" nor back to the future.
regards,
Carlos
Old 15th October 2012, 08:13 AM   #7117
Default Returning from job in the afternoon i will continue to play
Will try to modify the bass slope.
regards,
Carlos
Old 15th October 2012, 10:57 AM   #7118
R.I.P.
Originally Posted by vargasmongo3435 View Post
........................ the center tap is already connected to the center of the board, the red is the top side of the board and the blue one the bottom but if I'm wrong I will check it again, when you refer to "narrow" is the blue one or the red one that has to be change it to avoid the pulses?................
move the centre tap connection the space right next to the rectifier.
Remember the charging pulses run around the circuit from secondary/rectifier/first+ve cap/centretap/secondary/rectifier/first-ve cap/centre tap and repeats on every cycle. You don't want the traces carrying these pulses (in a figure of 8) to be shared with any circuit downstream of the charging circuit.
Look at the area between the first 4 smoothing caps.
There is a very wide Zero volts trace running from left to right through that space. Narrow the trace to maybe 5mm wide. This will help keep the charging pulses to the left side of the narrowing. Then the Zero volts side to the right of the narrowing will have much less of the charging pulses imposed on it. That should help "clean up" the output side of the PSU.
regards Andrew T.
Old 15th October 2012, 11:10 AM   #7119
R.I.P.
V,
the +ve rail trace and the -ve rail trace connecting all the like poles of the smoothing capacitors can be improved.
Break the +ve trace between the first cap and the second. Break the +ve trace between the second cap and the third cap.
repeat this for the -ve side traces. And repeat on top and bottom sides.
Insert pads to allow shorting links to be soldered in to maintain trace continuity from transformer end to the output end.
Now the OPTIONAL improvement:
replace the first +ve link and the first -ve link with radial resistor that fits the little gap at the edge of the PCB.
This changes the PSU from rCCC to rCRCC.
The second OPTIONAL improvement:
replace the second +ve link and the second -ve link with radial resistor that fits the little gap at the edge of the PCB.
This changes the PSU from rCRCC to rCRCRC.
The R can be any value dependant on current demand. I'd suggest the quiescent Vdrop across the first resistor be <300mVdc and across the second resistor <100mVdc.
You can replace these resistors with air cored handwound inductors with a R value (the copper wire resistance) ~ = the the R value that gave those same voltage drops I suggested above.
For a little amplifier say ~100W (Iq~100mA) the resistors could be 0r33 (1st) and 0r22 (2nd)
for a big amp say 300W (Iq~600mA), the resistors could be reduced to ~ 0r22 & ~ 0r1
regards Andrew T.
Old 15th October 2012, 06:52 PM   #7120
endia is offline endia  Turkey
Hi Carlos and hi all,
i designed this pcb from your schematic;
Greg's Web Site
and inspired from this pcb design;
TO-3 SYMASYM
just want to be sure before etching if it has any error or fine to go?
thanks..
Closed Thread
Destroyer x Amplifier...Dx amp...my amplifierHide this!Advertise here!
