Destroyer x Amplifier...Dx amp...my amplifier
Old 31st December 2009, 05:32 AM   #6591
lycanlk is offline lycanlk  Sri Lanka
Thumbs up Dear Carlos and friends,
First of all let me wish you all a very happy new year 2010 !
Sorry for not being in touch with you all.. But I have not given up Dx corporation.
Past few days I have tested Dx with a few amps.. Dx beats all of them by sound quality..
I wish if I can use Dx as a car amplifier with an SMPS.. I only concern the power efficiency (heating energy) and I'm sorry I dont know how to calculate those.. I heard FETs will generate low heat but poor sound quality..
Thanks all !
Old 31st December 2009, 05:51 AM   #6592
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default The amplifier is a classic class AB amplifier, eficiency is around 50 percent alike
others, you need 10 by 10 centimeters aluminium plate to each 10 watts of rms audio power.
To evaluate the heatsinks you may have at home, or even units to be sold in shops or internet, calculate area exposed to the air, both faces calculated,both aluminium face sides and them divide by two, and then enter the rule of three numbers to know how that unknow heatsink can hold in rms audio watts power.
You see, this is already converted to audio rms power,not heat, not watts of heat, not peak nor peak to peak.
So, a 50 watts rms audio amplifier (Dx amplifier working with 8 ohms speaker and 35 plus 35 volts in the power supply) needs the equivalent of 5 blades of aluminium exposed to the free air (out from case, out from enclosure, outside the cabinet) to dissipate the heat.
2 channels will need twice the number of blades, and if working 4 ohms you will multiply by four.
Imagine you found a heatsink with 16 fins, and each one of them measure 10 by 15 centimeters.
Each thin is 300 square centimeters, multiplied by the number of fins result 4800 square centimeters...then divide by two, this results 2400 square centimeters,
As each 10 by 10 centimeters (200 square centimeters divided by two result 100 square centimeters) hold 10 watts rms.... how many 100 square centimeters you have inside 2400 square centimeters?
24 times 10 watts!
Means the heatsink is able to dissipate 240 watts rms of AUDIO power, sinusoidal, continuous steady tone, in a 30 degrees centigrade environment.
Yes, we have more than fins, we have the heatsink base panel, and has length and high, and this dissipates too, but really not too much because heat turbulence under convection, you can forget the base for simplification purposes.
Attached an image, an example, how to calculate a strange heatsink with different shape.
This is all i can do for help you dear Lycanlk.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 31st December 2009, 06:23 AM   #6593
Default I do not like to talk about what is my evaluation about fets
They were made for switching power supplies, low resistance when the state is on and very high resistance when the state is off.
Can hold big current, the base is sensitive to destruction, not linear as normal transistors (BGT)
I do not like the sonics, i do not like them, but there are controversies.
Keep the old and good normal transistors for safety reasons my dear, do not enter that adventure.
Sounds strange to me, the sonics are strange to me.
Other love them deeply, so, there are several different opinions about, nothing is absolute in our universe...also nothing is solid, nor lead or iron or gold.
There are enormous empty spaces between electrons..things are not the way we imagine, fets too!
Wanna a clue, if i was not clear enougth?.... i have around 100 power fets, i am not using them, i have used several to test, i have made amplifiers with them, and i am not using them..... understood?
regards,
Carlos
Old 31st December 2009, 10:40 AM   #6594
most FET output stages need a higher supply voltage to deliver the same output power as the equivalent BJT output stage.
This high supply voltage results in more power dissipation and lower efficiency.
regards Andrew T.
Old 31st December 2009, 11:39 AM   #6595
Default I believe you...
I built a famous FET amp grabbed from this forum. I dont like to mention his name caz I appreciate his effort. Also It can handle my woofers well but I don't feel much comfortable with it. So I thinks its because of FETs. It produces good bass but not mid and trebles.
And thanks for the info which is enough me to select a good heatsink for Dx amp..
one more thing I have to consider when designing a car amp. That is to save the battery as much as I can. So decisions will tolerate between the quality against efficiency. isn't it?
Since Andrew has mentioned FET too dissipate more energy due to high power operation then the choice is more bias to old type good transistors
Old 31st December 2009, 11:46 AM   #6596
if efficiency is a concern then some kind of switching amp can be the only solution.
regards Andrew T.
Old 10th January 2010, 06:59 AM   #6597
Default Dx Standard sound special in the low end, excelent for subwoofer
applications, the overal performance is also excelent, despite beated by the Dx Blame ES, still continue to be a lovely amplifiers and there are several folks that have more modern and better performance amplifiers, but they still loves the warm and delicious sonics this amplifier produces (reproduces)
regards,
Carlos
Old 11th January 2010, 07:12 PM   #6598
Default I always appreciate DX sonics..
Dear Carlos,
Can I bridge 2 Dx amps to produce more power ? If yes then the amps will see the half of the impedance of speakers.. isn't it ? so how about the Dx operations under 2 ohms load ?
Lycanlk
Old 11th January 2010, 07:27 PM   #6599
Default I do not think bridge amps sounds fine, they add distortions
And to protect the Dx amplifier good name i will not suggest you to do that.
Of course, any amplifier can be bridged, so the Dx amplifier can be too, and this you know very well.
I do not like the idea, but the amplifier is yours and you do what you want to do...it i up to you.
regards,
Carlos
Old 11th January 2010, 09:04 PM   #6600
Thumbs up understood....
Thanks for the advice
Destroyer x Amplifier...Dx amp...my amplifierHide this!Advertise here!
Copyright ©1999-2017 diyAudio
