Destroyer x Amplifier...Dx amp...my amplifier
Old 1st July 2007, 11:22 PM   #2051
gaetan8888 is offline gaetan8888  Canada
Default Re: I felt a little bit more controled, the bass, reducing it since the input.
Originally posted by destroyer X
Try to install a 82N capacitor into the input.. substituting others that you have there... a single one to block subsonic and attenuate low end
Try to reduce R11 to 33K
Reduce C10 to 100uf
Install 0.47 ohms emitter resistances under the board.... this is the worst modifications i think, because turn the bass more controlable, less loosen but also much less punchy...the thunderstorm punch of the bass is lost in the name of superb fidelity, astonishing quality and impressive capacity to hold instruments producing nice figure at numbers......
regards,
Carlos
Hello
I remember Hugh Dean, in a 2004 Aksa thread, say that the 0.47 ohms emitter resistances was for the output to have more linearity.
What do you mean "producing nice figure at numbers" is it the soundstage ?
I do learn a lot in the Dx amp thread.
Gaetan
Old 1st July 2007, 11:24 PM   #2052
ecat is offline ecat  United Kingdom
ecat's Avatar
So close...
If I do any more tonight it's likely that I'll forget to go to bed
Old 2nd July 2007, 07:15 AM   #2053
sandyK is offline sandyK  Australia
Default Destroyer X Amplifier
Carlos
You could always compromise with 0R22 instead. A little local NFB can be very beneficial as you mentioned.
SandyK
Old 2nd July 2007, 09:38 AM   #2054
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default It is very impressive how fast you are Ecat..... also Microp is working fast too
I am happy to see you both moving.
Related emitter resistance...the standard Dx amplifier has not those resistances as you know.
About the sonic differences, give a try in your own unit...one channel with emitter resistance and the other using it...and compare.
I think the best way to conclude things is to listen.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 2nd July 2007, 11:59 AM   #2055
Default I now you have not finished the construction Ecat
But it is not bad to remember folks that a jumper here will be needed.
regards,
Carlos
Old 2nd July 2007, 12:14 PM   #2056
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Hey Ali-X,
why don't you do us a favor, dress up as Eduardo and stroll into the Audiopax building to shop for a single-ended transistor amp some folks would like to peekaboo inside.
You've had a towel around your head, as long as you haul the merchandise you can wear a lady pantyhose for what i care.
(Rua Alvaro Alvim 31/1302, Rio de Janitor)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 2nd July 2007, 12:21 PM   #2057
Default Transistor position will depend of the unit selected
This image shows the more standard one..... The BC556 and BC557.
regards,
Carlos
Old 2nd July 2007, 12:23 PM   #2058
Default Naah Vermeullen
Naah!
I have born in Rio de Janeiro city..... Alvaro Alvim is there!...say...the street.
I am in Recife.... around 2 thousand miles into Northeast direction.... i do not feel we have Alvaro Alvim, Avenue or street, here.
Also i do not understand English very well...decode messages as i cannot read them coded...because poor English reading.
regards,
Carlos
Old 2nd July 2007, 01:08 PM   #2059
Default Brasil size is enormous dear Jacco Vermeullen
Brasil área is bigger than Australia.
Some data to you and forum folks.
regards,
Carlos
Old 2nd July 2007, 01:17 PM   #2060
ecat's Avatar
Default Re: Transistor position will depend of the unit selected
Indeed, it would by typical of me to forget. From now on I'll fit the jumpers at the start while fitting the resistors
The other component that I would typically get wrong is C12 the 47uf 70v capacitor. I totally missed this when buying parts, luckily the local store had 5 100v parts and I found a 6th in an old TV
This is where the pictures of everyone's boards can become very confusing, I know I've had to check and double check and draw a picture and have a coffee and check again - lol, very confusing. For the record and any passing strangers, I'm using 2N5401 transistors for Q1 and Q2.
Destroyer x Amplifier...Dx amp...my amplifierHide this!Advertise here!
Copyright ©1999-2017 diyAudio
