hi having just replaced a blown channel in my nakamichi amplifier 1, i quite fancy replacing the big power caps which are nichicon great supply negative 10000uf 63v, these i gather are no longer avalible has anyone an idea of sutible replacements, also can i raise the value of the caps without any problems?
thanks. |
#2 | |
Hi Piercarlo |
#3 |
Piercarlo Thats 10,000 mfd not 10 mfd.
Reddish I have a couple 10,000 @ 80vdc 105 degree Nichicons.Email me if your interested. (New old stock) Cheers Dave
Ret. USAF... AKA- Avionic *** Solder slinger for hire...*** |
#4 | |
Hi Piercarlo |
#5 |
Hi Eagle,
you've got your milli and micro mixed up. From what I have seen in the past the US is terrible at sticking to the convention and mis-use both m and M when they mean something else. Some even get k & K mixed up.
regards Andrew T. |
#6 |
I have a Bunch of 10,000uF 63v Samwah Snap in Capacitors (NOS) and I can sell you a few for a Good price if you want them, Like maybe $3 or $4 each Pluss shipping.....
Let me know if you are interested.... Cheers |
#7 | ||
Andrew
So they don't use "uuf" anymore or "mfd" damn!!! Its like learning this stuff all over again. Give me time guys hell I just got the hang of 2k2 being 2.2 kilohm.Little steps...LOL
#8 | |
Andrew
Just so I don't misinterperate again Quote:
Dave
#9 |
k=kilo=10^3 multiplier. K=degree Kelvin= temperature units. K seems to be interchangable with C, I don't know if there is a definition difference. Can someone enlighten? All the multipliers above 1times are upper case except k to avoid confusion with K. All the multipliers below 1times are lower case and that also avoids confusion between m & M (pity some still confuse u & m (u=mu=micro=10^-6).
regards Andrew T. |
#10 |
I think the Nichicon Great Supply series of caps were replaced by the Super Through (KG) series.
http://www.nichicon-us.com/english/s...arg/list_f.htm A link to a pdf for the KG series is at the bottom. The only outfit I know that sells them is Michael Percy in the US: http://www.percyaudio.com/ Scott
"The Adobe Updater must update itself before it can check for updates. Would you like to update the Adobe Updater now?" -Adobe Updater |
| replacement caps for 107 crossover | dayking79 | Multi-Way | 5 | 18th May 2009 12:22 PM |
| Replacement Caps for a SSL Console? | moamps | Parts | 0 | 12th February 2005 05:02 PM |
| Which replacement caps for 47uF/16V non-polar? | Sampsa | Parts | 0 | 7th June 2004 03:29 AM |
| replacement caps - newbie question | MEGA-amp | Parts | 7 | 5th November 2003 03:33 PM |
| replacement tweeter caps | Dave Jones | Multi-Way | 2 | 27th August 2003 06:14 PM |
| Page generated in 0.12276 seconds (67.85% PHP - 32.15% MySQL) with 11 queries |
