| Thread Tools | Search this Thread |
#671 |
Quickly built over the holiday season from things that happened
to be here: 600 pV/sqrt(Hz) noise density, flicker corner in the very low Hz. 1 MHz flat bandwidth @ 60 dB gain 300 KHz flat bandwidth @ 80 dB gain Lower frequency corner is DC if offset servo is defeated, <1 Hz otherwise. It's fun if your scope shows 200 nV/div, but that makes sense only with an external lowpass because of noise bandwidth. Circuit is built on Vero powerplane board. This has a ground plane between the predrilled plated-tru pads. Just scratch away the lacquer and apply a little more tin to have a near perfect ground connection. regards, Gerhard
Everything has been said already - but not yet by everyone. (Karl Valentin) |
#672 |
What is that thing? A phono amp?
#673 | |
(probably with reduced gain ), but I'll use it in front of the FFT analyzer to measure noise in voltage references or phase noise in oscillators.
#674 |
.. and closed.
Fastening the 20 screws for top & bottom feels like assembling a cylinder head.
#675 | |
It seem like you have some knowledge in vhf and uhf design. Stinius |
#676 | |
Very nice pictures Regards Stinius |
#677 |
Bonsai,
Nice job on the preamp! Is the blue finned part shown in post #656 a bridge rectifier? Who makes it? Thanks. |
#678 |
Hello fritz39.
The blue finned thing on the right is the Amveco transformer - you can get it from digi-key. |
#679 |
Thanks for the compliment by the way!
#680 |
Continuing with our projects.
20 years ago I built a replica of the Quad 405 amplifier. Overview. |
| Page generated in 0.09973 seconds (64.88% PHP - 35.12% MySQL) with 11 queries |
