Old 30th July 2008, 07:03 AM   #411
Hi again Fotios
Likewise to you - very nice boards & construction. I really like seeing other people's boards/construction, as it always gives ideas for the next project
Best regards
smithy
Old 30th July 2008, 07:11 AM   #412
fotios is offline fotios  Greece
fotios's Avatar
Originally posted by smithy666
Hi again Fotios
Best regards
smithy
Many thanks my friend.
During this time i am in the process of drawing the power supply board, including also the protection computer. It is a big board. For this reason i have not posted curves yet, because untill now the module supplied from my Lab power supply. When the project completed, then i will post the curves.
Fotios
Old 30th July 2008, 07:33 AM   #413
lineup is offline lineup  Sweden
lineup's Avatar
Nice one, Bonsai
Here: http://www.diyaudio.com/forums/attac...amp=1171370431
My own picture shows a small solid state devices.
Think nobody can guess what it is .........
Discrete & symmetrical, as usual from my Lineup Audio Lab.
Battery for compare of actual size.
lineup
Old 30th July 2008, 07:44 AM   #414
fotios's Avatar
Originally posted by lineup
Nice one, Bonsai
Hi Lineup
It is a discrette operational amplifier for use in preamplifiers?
The only that i can say with certainty, is that it is not implemented with symmetrical LTPs as you like usually.
Greetings from Hellas
Fotios
Old 30th July 2008, 07:45 AM   #415
lineup's Avatar
Here is my workbench .. in the notorius Lineup Audio Lab.
A bit messy perhaps.
But like in painter's studio .. where is creative creation in colours going on
here Must be A Sort of Mess & Mixture
lineup
Old 30th July 2008, 07:47 AM   #416
lineup's Avatar
Originally posted by fotios
Hi Lineup
Greetings from Hellas, Fotios
No.
It is symmetrical alright. But not a differential pair ....
For use in pre amplifiers, yes.
lineup
Old 30th July 2008, 07:59 AM   #417
fotios's Avatar
No.
Then you are using two complementary transistors to share the input, which in sequence drive two complementary output transistors. Obviously, you are not using LTP configuration in feedback. Also the feedback it is DC coupled in GND, giving thus a low feedback ratio to obtain a wideband response.
Am i right now?
Fotios
Old 30th July 2008, 08:12 AM   #418
lineup's Avatar
Okay.
One NPN + one PNP put together, for temp compensation only.
This circuit is a discrete Symmetrical Shunt diode.
Each diode make 7.50 Volt from middle = 0 Volt.
To use this, you fead this symmetrical mirrored two VBE Multipliers
from two 9 VDC battery, with middle = 0 Volt.
As with shuntdiodes (zener) you have to put resistor to provide current into shunt.
Say 2 x 9.0 VDC input and 2 x 7.50 VDC output.
Makes 9.0-7.5 = 1.50 Volt drop.
Fead this symmetrical zener from two 1k5 resistors. 1 mA will flow through those VBE multipliers.
This one is not used as 2 x 7.50 Volt shunt regulator.
It is used for making 2 x 7.50 symmetrical Reference Voltages.
For my pre amplifier circuit.
lineup
Old 30th July 2008, 09:59 AM   #419
fotios's Avatar
Okay.
Well, this is a realy new and very smart invention.
What can i say then?
My compliments sir!
I asked your colaboration in building a preamplifier. If you are interested, give me a link to contact with you privatelly.
Greetings
Fotios
Old 30th July 2008, 10:45 AM   #420
Mooly's Avatar
Lineup,
Your workbench -- it is missing two vital items. Large hammer for minor adjustments and a supply of hog bars and "KitKats"
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
momo blast
Page generated in 0.13177 seconds (76.17% PHP - 23.83% MySQL) with 11 queries
